[mpich-discuss] make install issue
Dave Goodell
goodell at mcs.anl.gov
Fri Feb 19 11:25:20 CST 2010
It doesn't look like the problem is coming from MKDIR_P (although
reading that macro I think I just spotted a separate bug there too).
The problem is that our makefile is using "INSTALL_DATA=confdb/install-
sh" as determined by AC_PROG_INSTALL [1] in a subdirectory. Because
this is a relative path, when the make process changes directories it
can no longer find the program. Even worse than this being a relative
path, it's a relative path with an implicit current directory (there
is no explicit "." at the start).
I suspect this happens because your machine doesn't have a proper
"install" program written in C, so it falls back to using the included
"install-sh". We do all of our testing on platforms with working
"install" programs, so we never see this case.
The short term workaround for you is to re-configure and pass
"INSTALL=MPICH2_SOURCE_DIR/confdb/install-sh", replacing
"MPICH2_SOURCE_DIR" with a real path to the MPICH2 source
distribution. I'll file a new ticket to remind us to fix this up
somehow.
-Dave
[1] http://www.gnu.org/software/autoconf/manual/autoconf.html#index-AC_005fPROG_005fINSTALL-262
On Feb 19, 2010, at 8:48 AM, Tai Huynh wrote:
> When I do a make install and it fails because confdb/install-sh is
> not found.
> My mpich2-1.2.1 already have the fix of r5801 (AC_PROG_MKDIR_P is
> broken; it's using a version check on
> mkdir to figure out whether to use "mkdir -p", instead of something
> else. Also added a comment explaining this issue.).
> https://trac.mcs.anl.gov/projects/mpich2/ticket/939
> I am running on a:
> SunOS stratego 5.10 Generic_141444-09 sun4u sparc SUNW,Sun-Fire-V240
> f95: Sun Fortran 95 8.3 SunOS_sparc Patch 127000-01 2007/07/18
> Thank you for you help,
> Tai Huynh
> <install.txt>
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
