[mpich-discuss] make install issue
Tai Huynh thuynh at vni.com
Fri Feb 19 08:48:50 CST 2010
When I do a make install and it fails because confdb/install-sh is not found.
My mpich2-1.2.1 already have the fix of r5801 (AC_PROG_MKDIR_P is broken; it's using a version check on
mkdir to figure out whether to use "mkdir -p", instead of something
else. Also added a comment explaining this issue.).
https://trac.mcs.anl.gov/projects/mpich2/ticket/939
I am running on a:
SunOS stratego 5.10 Generic_141444-09 sun4u sparc SUNW,Sun-Fire-V240
f95: Sun Fortran 95 8.3 SunOS_sparc Patch 127000-01 2007/07/18
Thank you for you help,
Tai Huynh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100219/477207cc/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100219/477207cc/attachment.txt>
