[mpich-discuss] mpich doesn't work well in the cygwin on Windows 7 64 bit
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Feb 10 09:38:27 CST 2010
Can you see if hydra (the new process manager that will replace mpd as the default process manager in upcoming releases) works for you (mpiexec.hydra -n 2 ./runSBML-PET.exe)?
Jayesh
----- Original Message -----
From: "Zhike Zi" <zhike.zi at bioss.uni-freiburg.de>
Sent: Wednesday, February 10, 2010 4:11:57 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] mpich doesn't work well in the cygwin on Windows 7 64 bit
Dear List,
I have installed mpich2-1.2.1 in my cygwin (v1.7.1) on Windows 7 64 bit machine. I didn't get any error message during the building and installation. mpdcheck doesn't report any problem. However, when I try to start mpi in cygwin, I got the following error messages. I also tested the version of mpich2-1.0.8, I got the same problem. It worked well in the cygwin on my Windows XP PC.
$ mpd &
[1] 2684
$ mpdtrace
mpdtrace (mpdtrace 57): got eof on console
$ mpdcheck
$ mpdcheck -v
obtaining hostname via gethostname and getfqdn
gethostname gives Zi-PC
getfqdn gives Zi-PC
checking out unqualified hostname; make sure is not "localhost", etc.
checking out qualified hostname; make sure is not "localhost", etc.
obtain IP addrs via qualified and unqualified hostnames; make sure other than 1
27.0.0.1
gethostbyname_ex: ('Zi-PC', [], ['10.5.235.x'])
checking that IP addrs resolve to same host
now do some gethostbyaddr and gethostbyname_ex for machines in hosts file
$ mpirun -np 2 ./runSBML-PET.exe
mpiexec_Zi-PC (mpiexec 257): no msg recvd from mpd during version check
$ mpdallexit
mpdallexit (recv_dict_msg 582):recv_dict_msg: errmsg=:cannot concatenate 'str' a
nd 'int' objects:
mpdtb:
/usr/local/bin/mpdlib.py, 582, recv_dict_msg
/usr/local/bin/mpdallexit, 50, mpdallexit
/usr/local/bin/mpdallexit, 59, <module>
mpdallexit (mpdallexit 52): no msg recvd from mpd before timeout
The configure log is attached.
Does any one have the problem? I am looking forward to any suggestions and helps.
Thank you for the attention.
Best regards,
Zhike Zi
Centre for Biological Signalling Studies (bioss)
University of Freiburg
mpich-discuss mailing list
