[mpich-discuss] MPICH2 and Windows 7
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Feb 10 09:36:19 CST 2010
>>> mpiexec -validate (NOK, I get the following error message: Aborting: connection to smpd rejected)
Here is your problem. The "-validate" command should be successful.
Is the user a domain user (In that case did you specify the domain name when registering the username)?
Can you try pressing enter (The enter key) when "mpiexec -register" prompts for a username (Then mpiexec should pick the current username)? After using the default/current username please specify the password for the user when mpiexec prompts for the password.
Also we recommend installing the 64-bit version of MPICH2 if your windows OS is 64-bit.
Let us know if it works for you.
Jayesh
----- Original Message -----
Sent: Wednesday, February 10, 2010 5:08:37 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] MPICH2 and Windows 7
Hello.
I have troubles to use MPICH2 with Windows 7 32 bits.
Installation is OK (installation program mpich-1.2.1-win-ia32.msi).
The smpd service is up and running.
Then I open a windows command with administrator privileges, and try to register, using the following commands:
mpiexec -remove (OK)
mpiexec -register (with my domain name, user name & password) (OK)
When I try to lauch a MPI program of my own, compiled with MPICH2 and MSVC2008, I get the following error message:
Aborting: unable to connect to grimbergen.alyotech.fr (grimbergen is my host name).
I also tried to use wmpiconfig to get the hosts, then retrieve the settings of my computer grimbergen.
I then get the error message "GRIMBERGEN: MPICH2 not installed or unable to query the host".
I tried to turn off the firewall, and to add "mpiexec" and "smpd" to the list of progams allowed by the firewall, but without success.
I tried to add MPICH2\bin directory to the system path, without success too.
Is there any configuration tuning I can try to use MPICH2 with Windows 7 ?
Thanks in advance.
Best regards,
Eric Monteux.
mpich-discuss mailing list
