[mpich-discuss] MPICH2 & Windows 7
Jayesh Krishna jayesh at mcs.anl.gov
Thu Feb 4 09:08:22 CST 2010
 Great! Let us know if you need any help.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Wednesday, February 3, 2010 4:47:56 PM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] MPICH2 & Windows 7
Both worked. Thanks a lot!
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, February 03, 2010 3:29 PM
To: Xu, Liyang
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] MPICH2 & Windows 7
 There is no additional step required to get your code running. If you have the windows firewall turned on, try turning it off.
 First try running a non-MPI program using mpiexec,
    mpiexec -n 2 hostname
 Now try running a simple MPI hello world program (https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/hellow.c),
    mpiexec -n 2 hellow.exe
 Let us know if it works.
Jayesh
Sent: Wednesday, February 3, 2010 4:05:21 PM GMT -06:00 US/Canada Central
Hi Jayesh,
Thanks for your email.
I have installed MPICH2 correctly with no error message.
(i.e. cmd run as administrator -> msiexec /i mpich2-1.2.1-win-x86-64.msi)
Then, I have rebuilt by application code. But when I was trying execute it, either in a cmd window opened as administrator, or not, the program was just hung there (my test program is very simple, it should return within a second).
The way I started my mpi job was:
mpiexec -n 1 WtDemoRunt1D.exe
I am wondering if there are extra steps needed to execute my code. What are right steps to launch an MPI job?
Thanks again,
Liyang
Sent: Wednesday, February 03, 2010 10:20 AM
Cc: Xu, Liyang
 Were you able to install MPICH2 successfully (Did you get any error messages during the install)?
 Typically on Windows 7 you will have to install MPICH2 from an admin command prompt (Right-click on command prompt --> Select "Run as administrator" --> In the command prompt type "msiexec /i mpich2-1.2.1-win-x86-64.msi") or you will have to install SMPD separately(after installing MPICH2) from an admin command prompt (Right-click on command prompt --> Select "Run as administrator" --> In the command prompt type "smpd -install -phrase MYPASSPHRASE").
Jayesh
Sent: Tuesday, February 2, 2010 6:27:18 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] MPICH2 & Windows 7
I have installed MPICH2 on a 64-bit Windows 7 machine. I have turned off the firewall, but still I got the following message:
c:\MZA\wavetrain\trunk\examples\wtdemo>mpiexec -n 1 WtDemoRunt1D.exe
Error while connecting to host, No connection could be made because the target m
achine actively refused it. (10061)Connect on sock (host:sandia.mza.lan, port=8676) failed, exhaused all end points
Unable to connect to 'sandia.mza.lan:8676',
sock error: Error = -1
How can I fix that problem?
Thanks!
mpich-discuss mailing list
