[mpich-discuss] MPICH2 & Windows 7
Jayesh Krishna jayesh at mcs.anl.gov
Wed Feb 3 11:20:18 CST 2010
 Were you able to install MPICH2 successfully (Did you get any error messages during the install)?
 Typically on Windows 7 you will have to install MPICH2 from an admin command prompt (Right-click on command prompt --> Select "Run as administrator" --> In the command prompt type "msiexec /i mpich2-1.2.1-win-x86-64.msi") or you will have to install SMPD separately(after installing MPICH2) from an admin command prompt (Right-click on command prompt --> Select "Run as administrator" --> In the command prompt type "smpd -install -phrase MYPASSPHRASE").
Jayesh
----- Original Message -----
Sent: Tuesday, February 2, 2010 6:27:18 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] MPICH2 & Windows 7
I have installed MPICH2 on a 64-bit Windows 7 machine. I have turned off the firewall, but still I got the following message:
c:\MZA\wavetrain\trunk\examples\wtdemo>mpiexec -n 1 WtDemoRunt1D.exe
Error while connecting to host, No connection could be made because the target m
achine actively refused it. (10061)Connect on sock (host:sandia.mza.lan, port=8676) failed, exhaused all end points
Unable to connect to 'sandia.mza.lan:8676',
sock error: Error = -1
How can I fix that problem?
Thanks!
mpich-discuss mailing list
