[mpich-discuss] ubuntu install
Rajeev Thakur thakur at mcs.anl.gov
Tue Feb 2 14:43:52 CST 2010
See Section 5.1.6 on pg 18 of the MPICH2 installation guide for how to run MPD as root
http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Guido
> Vettoretti
> Sent: Tuesday, February 02, 2010 2:23 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] ubuntu install
> Hi,
> I installed mpich2 under ubuntu using synaptic package manager and
> everything went fine. The problem I'm getting is I can't mpiexec as a
> regular user , only as root
> I have an /etc/mpd.conf file set as chmod 600
> I have a /home/user/.mpd.conf file
> I have run mpd & as user and/or root
> but I get this error:
> /shared/bin/mpdroot: open failed for root's mpd conf
> filempdtrace (__init__ 1171): forked process failed; status=255
> http://debianclusters.cs.uni.edu/index.php/MPICH:_Troubleshoot
ing_the_MPD
> I had to change a couple of things to get mpiexec to work as user:
>     run mpd --daemon as root
>     chown user\: /etc/mpd.conf
>     chown user\: /tmp/mpd2.console_root
> to get mpiexec to work.
> This is not a good solution. Does anyone have a good explanation for
> this behaviour. My user wants to user the root mpd , why?
> Thanks
> Guido
> mpich-discuss mailing list
