[mpich-discuss] Hydra
Pavan Balaji balaji at mcs.anl.gov
Wed Dec 29 03:17:15 CST 2010
Mark,
I've committed some fixes along this direction in r7620. Would you be
willing to try out the latest nightly snapshot to see if it works for you?
If you only want the new mpiexec:
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra
If you want the entire MPICH2 tarball:
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/trunk
  -- Pavan
On 12/15/2010 12:12 PM, Mark Beauharnois wrote:
> Pavan, thanks very much for the clarification!
> -----Original Message-----
> From: Pavan Balaji [mailto:balaji at mcs.anl.gov]
> Sent: Wednesday, December 15, 2010 12:44 PM
> To: mpich-discuss at mcs.anl.gov
> Cc: Mark Beauharnois
> Subject: Re: [mpich-discuss] Hydra
> On 12/15/2010 11:09 AM, Mark Beauharnois wrote:
>> On 'minserv1' we execute:
>> [minserv1 ~] $mpdboot --totalnum=2 --ncpus=8 --ifhn=minserv1-gig -f
>> ${HOME}/mpd.hosts
> MPD is the old process manager. With Hydra that's not needed.
>> [proxy:0:1 at minserv2] HYDU_sock_connect (./utils/sock/sock.c:138): unable
>> to get host address (Success)
>> [proxy:0:1 at minserv2] main (./pm/pmiserv/pmip.c:208): unable to connect
>> to server minserv1 at port 55501 (check for firewalls!)
>> We&  #8217;re that 'minserv2' appears to be trying to connect to
>> 'minserv1' (the using the non-gigabit interface) when we've started mpd
>> with the specification to explicitly use that interface?
> The host names specified in the host file will be used for all MPI
> communication. However, the process manager control traffic still goes
> over the default interface; in your case that's the non-gigabit
> interface. This is not performance critical, but requires the default
> interface to be functional.
> As a short term work-around, can you make sure that the default network
> interface can also be used for communication (for the control traffic)?
> I'll try to fix this for the upcoming release.
>    -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
