[mpich-discuss] Using MPI_Put/Get correctly?
    Grismer,	Matthew J Civ USAF AFMC AFRL/RBAT
    Matthew.Grismer at wpafb.af.mil
    Thu Dec 16 12:33:22 CST 2010
I am trying to modify the communication routines in our code to use
MPI_Put's instead of sends and receives.  This worked fine for several
variable Put's, but now I have one that is causing seg faults. Reading
through the MPI documentation it is not clear to me if what I am doing
is permissible or not.  Basically, the question is this - if I have
defined all of an array as a window on each processor, can I PUT data
from that array to remote processes at the same time as the remote
processes are PUTing into the local copy, assuming no overlaps of any of
the PUTs?
Here are the details if that doesn't make sense.  I have a (Fortran)
array QF(6,2,N) on each processor, where N could be a very large number
(100,000). I create a window QFWIN on the entire array on all the
processors.  I define MPI_Type_indexed "sending" datatypes (QFSND) with
block lengths of 6 that send from QF(1,1,*), and MPI_Type_indexed
"receiving" datatypes (QFREC) with block lengths of 6 the receive into
QF(1,2,*).  Here * is non-repeating set of integers up to N.  I create
groups of processors that communicate, where these groups will all
exchange QF data, PUTing local QF(1,1,*) to remote QF(1,2,*).  So,
processor 1 is PUTing QF data to processors 2,3,4 at the same time 2,3,4
are putting their QF data to 1, and so on.  Processors 2,3,4 are PUTing
into non-overlapping regions of QF(1,2,*) on 1, and 1 is PUTing from
QF(1,1,*) to 2,3,4, and so on.  So, my calls look like this on each
processor:
assertion = 0
call MPI_Win_post(group, assertion, QFWIN, ierr)
call MPI_Win_start(group, assertion, QFWIN, ierr)
do I=1,neighbors
  call MPI_Put(QF, 1, QFSND(I), NEIGHBOR(I), 0, 1, QFREC(I), QFWIN,
ierr)
end do
call MPI_Win_complete(QFWIN,ierr)
call MPI_Win_wait(QFWIN,ierr)
Note I did define QFREC locally on each processor to properly represent
where the data was going on the remote processors.  The error value
ierr=0 after MPI_Win_post, MPI_Win_start, MPI_Put, and MPI_Win_complete,
and the code seg faults in MPI_Win_wait.
I'm using MPICH2 1.3.1 on Mac OS X 10.6.5, built with Intel XE (12.0)
compilers, and running on just 2 (internal) processors of my Mac Pro.
The code ran normally with this configuration up until the point I put
the above in.  Several other communications with MPI_Put similar to the
above work fine, though the windows are only on a subset of the
communicated array, and the origin data is being PUT from part of the
array that is not within the window.
_____________________________________________________
Matt
