[mpich-discuss] Mpi-collective abort:
    Dave Goodell
    goodell at mcs.anl.gov
    Sat Aug 28 21:37:05 CDT 2010
I just noticed that I gave a bad link here.  The other link should work for 1.2.1p1, but this is the actual correct link:
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
-Dave
On Aug 27, 2010, at 8:14 AM CDT, Dave Goodell wrote:
> Please try the latest stable release of MPICH2, 1.2.1p1: http://www.mcs.anl.gov/research/projects/mpich2staging/goodell/downloads/index.php?s=downloads
> -Dave
> On Aug 27, 2010, at 4:33 AM CDT, Thejna Tharammal wrote:
>> Hi,
>> I'm using MPICH version 1.0.5, on linux cluster- with scientific linux
>> (2.6.18-128.1.6.el5, x86_64)
>> Thank you,
>> Thejna.
>> ----------------original message-----------------
>> From: "Rajeev Thakur" thakur at mcs.anl.gov
>> To: mpich-discuss at mcs.anl.gov
>> Date: Thu, 26 Aug 2010 15:54:32 -0500
>>> Which version of MPICH2 are you using and on what platform and OS?
>>> Rajeev
>>> On Aug 26, 2010, at 8:22 AM, Thejna Tharammal wrote:
>>>> I'm trying to run a model [CCSm, MPMD with 5 executables] on Intel xeon
>> 64 bit
>>>> cluster with 6 nodes(3Gz each,ethernet) , I use Mpi2 distributed with
>>>> pgi-7.2-5 , the model compiles without errors, but during run it shows,
>>>> 1: (cpl_domain_compare) domain #1 name: atm contract domain
>>>> 1: (cpl_domain_compare) domain #2 name: lnd contract domain
>>>> 1: (cpl_domain_compare) domain #1 name: ocn contract domain
>>>> 1: (cpl_domain_compare) domain #2 name: ice contract domain
>>>> rank 0 in job 1 xxxx_35825 caused collective abort of all ranks
>>>> exit status of rank 0: killed by signal 9
>>>> What could be the reason for this,
>>>> Thank you,
>>>> Thejna.
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
