[mpich-discuss] mpich2 parallel job real time.
mohamed makhyoun makhyoun2 at yahoo.com
Thu Aug 26 17:10:19 CDT 2010
Dear Dr. Reuti:
Thank you for your quick reply.
The number of nodes is decided using environmental variable CFOUR_NUM_CORES which was defined at the configuration script of cfour.
I restarted the same job by doing the following ;
export CFOUR_NUM_CORES=4
mpd &
mpdboot -f File  --ncpus=4
cfourbinary input > output
I noticed that starting the command ( top) confirms the presence of four cpus runing
on my computer, nevertheless the job finshed in real time close to the serial job !.
Best Regards
Mohamed
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100826/46c885ad/attachment.htm>
