[mpich-discuss] libmpich.a "No such file or directory"
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sun Aug 15 18:57:12 CDT 2010
That mpicc is from Open MPI, not MPICH2. Give the full path to mpicc.
On Aug 15, 2010, at 1:37 PM, sasha lambert wrote:
> That would be the following:
> $ mpicc -show
> gcc -D_REENTRANT -Wl,-u,_munmap -Wl,-multiply_defined,suppress -lmpi -lopen-rte -lopen-pal
> S
> On Sun, Aug 15, 2010 at 1:08 PM, michael.bane at manchester.ac.uk <michael.bane at manchester.ac.uk> wrote:
> What is output of mpicc -show
> Michael
> ----- Reply message -----
> From: "sasha lambert" <lambert.sasha at gmail.com>
> Date: Sun, Aug 15, 2010 17:32
> Subject: [mpich-discuss] libmpich.a "No such file or directory"
> To: <mpich-discuss at mcs.anl.gov>
> Still nothing : (   There must be something basic i'm missing, or syntax error somewhere. Hmm.
> Thanks for the help!
> Sasha
> On Sun, Aug 15, 2010 at 11:59 AM, Si Hammond <simon.hammond at gmail.com> wrote:
> Pretty odd.
> Have you tried specifying the exact path?
> mpicc -o /home/abcd/main.o main.c
> mpicc -o /home/abcd/hello /home/acbd/main.o
> S.
> On 15 Aug 2010, at 16:38, sasha lambert wrote:
>> Hmm still nothing; no errors but no main.o.
>> My mpich configure, make, and make install steps went smoothly. The "which mpicc" test was successful, indicating its location at usr/bin.
>> Sasha
>> On Sun, Aug 15, 2010 at 11:25 AM, Si Hammond <simon.hammond at gmail.com> wrote:
>> Can you try...
>> mpicc -o main.o -c main.c
>> mpicc -o hello main.o
>> You should see the main.o in the directory, if no errors on the screen then it sounds like its working fine.
>> S.
>> On 15 Aug 2010, at 16:21, sasha lambert wrote:
>>> I tried compiling using mpicc, and nothing seems to happen.
>>> The prompt just reappears and no executable file has been made.
>>> Sasha
>>> On Sun, Aug 15, 2010 at 11:12 AM, Si Hammond <simon.hammond at gmail.com> wrote:
>>> Have you tried compiling with mpicc?
>>> mpicc -o hello main.c
>>> This sets up the linking etc for you.
>>> S.
>>> On 15 Aug 2010, at 16:02, sasha lambert wrote:
>>>> I'm fairly new to unix and mpich, so please bear with me.
>>>> I've tried to compile a simple "hello" program below:
>>>> /*The Parallel Hello World Program*/
>>>> #include <stdio.h>
>>>> #include <mpi.h>
>>>> main(int argc, char **argv)
>>>> 	int node;
>>>> 	MPI_Init(&argc,&argv);
>>>> 	MPI_Comm_rank(MPI_COMM_WORLD, &node);
>>>> 	printf("Hello World from Node %d\n",node);
>>>> 	MPI_Finalize();
>>>> Here is the shell response:
>>>> $ gcc main.c -o hello
>>>> Undefined symbols:
>>>>   "_MPI_Comm_rank", referenced from:
>>>>       _main in ccWLoMyo.o
>>>>   "_MPI_Finalize", referenced from:
>>>>       _main in ccWLoMyo.o
>>>>   "_MPI_Init", referenced from:
>>>>       _main in ccWLoMyo.o
>>>> ld: symbol(s) not found
>>>> collect2: ld returned 1 exit status
>>>> I tried searching for "MPI_init" in libmpich.a, thinking it might have to do with the added underscore in " _MPI_Init".
>>>> Shell response:
>>>> $ nm libmpich.a | grep mpi_init
>>>> nm: can't open file: libmpich.a (No such file or directory)
>>>> I've added usr/local/lib to the PATH, but still nothing. Any suggestions?
>>>> Thanks,
>>>> Sasha
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Si Hammond
>>> Research Fellow & Knowledge Transfer Associate
>>> Performance Computing & Visualisation Group
>>> Department of Computer Science
>>> University of Warwick, CV4 7AL, UK
>>> http://go.warwick.ac.uk/hpsg
>> Si Hammond
> Si Hammond
