[mpich-discuss] libmpich.a "No such file or directory"
sasha lambert lambert.sasha at gmail.com
Sun Aug 15 13:37:57 CDT 2010
That would be the following:
$ mpicc -show
gcc -D_REENTRANT -Wl,-u,_munmap -Wl,-multiply_defined,suppress -lmpi
-lopen-rte -lopen-pal
S
On Sun, Aug 15, 2010 at 1:08 PM, michael.bane at manchester.ac.uk <
michael.bane at manchester.ac.uk> wrote:
> What is output of mpicc -show
> Michael
> ----- Reply message -----
> From: "sasha lambert" <lambert.sasha at gmail.com>
> Date: Sun, Aug 15, 2010 17:32
> Subject: [mpich-discuss] libmpich.a "No such file or directory"
> To: <mpich-discuss at mcs.anl.gov>
> Still nothing : (   There must be something basic i'm missing, or syntax
> error somewhere. Hmm.
> Thanks for the help!
> Sasha
> On Sun, Aug 15, 2010 at 11:59 AM, Si Hammond <simon.hammond at gmail.com>wrote:
>> Pretty odd.
>> Have you tried specifying the exact path?
>> mpicc -o /home/abcd/main.o main.c
>> mpicc -o /home/abcd/hello /home/acbd/main.o
>> S.
>> On 15 Aug 2010, at 16:38, sasha lambert wrote:
>> Hmm still nothing; no errors but no main.o.
>> My mpich configure, make, and make install steps went smoothly. The "which
>> mpicc" test was successful, indicating its location at usr/bin.
>> Sasha
>> On Sun, Aug 15, 2010 at 11:25 AM, Si Hammond <simon.hammond at gmail.com>wrote:
>>> Can you try...
>>> mpicc -o main.o -c main.c
>>> mpicc -o hello main.o
>>> You should see the main.o in the directory, if no errors on the screen
>>> then it sounds like its working fine.
>>> S.
>>> On 15 Aug 2010, at 16:21, sasha lambert wrote:
>>> I tried compiling using mpicc, and nothing seems to happen.
>>> The prompt just reappears and no executable file has been made.
>>> Sasha
>>> On Sun, Aug 15, 2010 at 11:12 AM, Si Hammond <simon.hammond at gmail.com>wrote:
>>>> Have you tried compiling with mpicc?
>>>> mpicc -o hello main.c
>>>> This sets up the linking etc for you.
>>>> S.
>>>> On 15 Aug 2010, at 16:02, sasha lambert wrote:
>>>> I'm fairly new to unix and mpich, so please bear with me.
>>>> I've tried to compile a simple "hello" program below:
>>>> /*The Parallel Hello World Program*/
>>>> #include <stdio.h>
>>>> #include <mpi.h>
>>>> main(int argc, char **argv)
>>>>  int node;
>>>> MPI_Init(&argc,&argv);
>>>>  MPI_Comm_rank(MPI_COMM_WORLD, &node);
>>>>  printf("Hello World from Node %d\n",node);
>>>>  MPI_Finalize();
>>>> Here is the shell response:
>>>> $ gcc main.c -o hello
>>>> Undefined symbols:
>>>>   "_MPI_Comm_rank", referenced from:
>>>>       _main in ccWLoMyo.o
>>>>   "_MPI_Finalize", referenced from:
>>>>       _main in ccWLoMyo.o
>>>>   "_MPI_Init", referenced from:
>>>>       _main in ccWLoMyo.o
>>>> ld: symbol(s) not found
>>>> collect2: ld returned 1 exit status
>>>> I tried searching for "MPI_init" in libmpich.a, thinking it might have
>>>> to do with the added underscore in " _MPI_Init".
>>>> Shell response:
>>>> $ nm libmpich.a | grep mpi_init
>>>> nm: can't open file: libmpich.a (No such file or directory)
>>>> I've added usr/local/lib to the PATH, but still nothing. Any
>>>> suggestions?
>>>> Thanks,
>>>> Sasha
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>> Si Hammond
>>>> Research Fellow & Knowledge Transfer Associate
>>>> Performance Computing & Visualisation Group
>>>> Department of Computer Science
>>>> University of Warwick, CV4 7AL, UK
>>>> http://go.warwick.ac.uk/hpsg
>>> Si Hammond
>> Si Hammond
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100815/4287683a/attachment-0001.htm>
