[mpich-discuss] install mpich2 on redhat
Pavan Balaji balaji at mcs.anl.gov
Thu Aug 12 08:33:56 CDT 2010
Hello,
I'm assuming that you used the binary install from Fedora directly (`yum
install mpich2`)?
Can you try mpiexec.hydra instead? Here are some usage instructions:
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
  -- Pavan
On 08/12/2010 03:29 AM, dxingya wrote:
> hi, I tried to install mpich2 on a redhat server which has 20 nodes and
> about 100 processors. When i run mpd, the screen output that
> /*configuration file /etc/mpd.conf is accessible by others, change
> permissions to allow read and write access only by you*/. I also can not
> run mpirun. I have successfully install mpich2 on windows. That's very
> easy. Why is it so hard to install mpich2 on redhat. All I have done is
> in the direction of install guild. Does any body kown how to install
> mpich2 on redhat. If so, please send me a file. Thanks.
> Da
> 网易邮箱,没有垃圾邮件的邮箱。 <http://mail.163.com/?from=fe1>
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
