[mpich-discuss] generating slog2 format trace data
Jeffrey S. Brown
jeffb at lanl.gov
Wed Aug 11 17:10:05 CDT 2010
that should do it - thanks
Jeff
> Hi Jeff,
> We don't have a very detailed documentation on the slog2
> data format. However, we have an API, called TRACE-API,
> that allows one to generate slog2 file programmatically
> (Several other groups had successfully used the API)
> The API is documented from p.22 to p.41 in the following document
> http://ftp.mcs.anl.gov/pub/mpi/slog2/slog2-draft.pdf
> Also, there is a sample implementation of TRACE-API
> in slog2sdk/trace_sample which should help to implement
> the callback API.
> A formal slog2 paper that describes the general
> features/structures of slog2 file:
> http://ftp.mcs.anl.gov/pub/mpi/slog2/slog2-paper.pdf
> Let me know if you have any questions.
> A.Chan
> ----- "Jeffrey S. Brown" <jeffb at lanl.gov> wrote:
>> folks,
>> We are interested in hooking up a locally developed performance
>> measurement tool to jumpshot. The idea is for our tool to generate
>> slog2 format
>> trace data then feed to jumpshot for visualization. In order to do
>> this we need detailed documentation on the slog2 data format. Can you
>> please
>> point us in the right direction?
>> thanks,
>> Jeff Brown, Los Alamos National Laboratory
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
