[mpich-discuss] generating slog2 format trace data
chan at mcs.anl.gov chan at mcs.anl.gov
Wed Aug 11 16:43:58 CDT 2010
Hi Jeff,
We don't have a very detailed documentation on the slog2
data format.  However, we have an API, called TRACE-API,
that allows one to generate slog2 file programmatically
(Several other groups had successfully used the API)
The API is documented from p.22 to p.41 in the following document
http://ftp.mcs.anl.gov/pub/mpi/slog2/slog2-draft.pdf
Also, there is a sample implementation of TRACE-API
in slog2sdk/trace_sample which should help to implement
the callback API.
A formal slog2 paper that describes the general
features/structures of slog2 file:
http://ftp.mcs.anl.gov/pub/mpi/slog2/slog2-paper.pdf
Let me know if you have any questions.
A.Chan
----- "Jeffrey S. Brown" <jeffb at lanl.gov> wrote:
> folks,
> We are interested in hooking up a locally developed performance
> measurement tool to jumpshot.  The idea is for our tool to generate
> slog2 format
> trace data then feed to jumpshot for visualization.  In order to do
> this we need detailed documentation on the slog2 data format.  Can you
> please
> point us in the right direction?
> thanks,
> Jeff Brown, Los Alamos National Laboratory
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
