[mpich-discuss] Cannot run MPI pgm on x5460
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Apr 29 16:15:16 CDT 2010
 From the error messages it looks like the MPICH2 process manager was not installed correctly on the system. Please let us know the status of the MPICH2 process manager by typing "smpd -status" at the command prompt.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Wednesday, April 28, 2010 11:05:40 AM GMT -06:00 US/Canada Central
Subject: Re: Cannot run MPI pgm on x5460
Thanks for the quick response, please see answers below:
--- On Wed, 4/28/10, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
Subject: Cannot run MPI pgm on x5460
To: "stan pade" <stan_pade at yahoo.com>
Cc: mpich-discuss at mcs.anl.gov
Date: Wednesday, April 28, 2010, 11:12 AM
Please provide us details on your problem.
# What is the OS installed on the machine ?
Windows Vista Business Service Pack 2
# Which version of MPICH2 is installed on the machine (Did you get any error messages during install ? )?
The Feb 22 2010 version, not sure about #, no errors during installation
# Where you able to run any MPI programs on the machine (Is this the first time ?)?
This is the first time
# What is the value of %MPIRUN% (Does it point to mpiexec from MPICH2)?
yes
# Can you run simple non-MPI programs like hostname (mpiexec -n 2 hostname)?
no
# Can you run simple MPI programs on the machine (mpiexec -n 2 c:\progra~1\mpich2\examples\cpi.exe)?
no, same error
# If you have any firewalls running on the machine, try turning the firewall off and re-running your code.
Turned off al firewalls, still same error
Jayesh
To: mpich2-maint at mcs.anl.gov
Sent: Wednesday, April 28, 2010 10:02:55 AM GMT -06:00 US/Canada Central
Subject: [mpich2-maint] (no subject)
I get the following error when trying to verify mpi installation on my x5460 machine. Can you offer any help?
Thanks
Stan Pade
c:\ldi\pOWERBALL\1004>%MPIRUN% -genvlist VNI_F90_MSG -n 4 imslmpi.exe
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host=Basia-Pc, port=8676) failed, exhaused all end points
Unable to connect to 'Basia-Pc:8676',
sock error: Error = -1
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
