[mpich-discuss] mpdboot error
Dave Goodell
goodell at mcs.anl.gov
Fri Apr 23 12:16:20 CDT 2010
Hi Jacob,
Can you post your mpdboot invocation? There is probably either a
mistake in that line or a bug in mpdboot.
-Dave
On Apr 23, 2010, at 11:41 AM, Jacob Harvey wrote:
> MPICH2 users,
> Has anyone seen this error from mpdboot before?
> Traceback (most recent call last):
> File "/opt/mpich2-1.2.1-i86/bin/mpdboot", line 476, in ?
> mpdboot()
> File "/opt/mpich2-1.2.1-i86/bin/mpdboot", line 158, in mpdboot
> totalnumToStart = int(argv[argidx+1])
> ValueError: invalid literal for int(): 2-f
> Its odd because I only get this error when I try to set up an mpd ring
> for calculations in a PBS script. But if I try to set up an mpd ring
> from the command line then the ring forms just fine. Plus I've gone
> through the debugging MPD rings in the manual and did not turn up any
> errors in doing so. Another puzzling piece of information is that I
> use the same exact PBS script on a different cluster and the mpd ring
> forms just fine. So I'm confused as to what is the problem here. Any
> thoughts? Thanks in advance!
> Jacob
> Jacob Harvey
> Graduate Student
> University of Massachusetts Amherst
> j.harv8 at gmail.com
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
