[mpich-discuss] Problems with MPI_Pcontrol and MPE2
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Thu Apr 22 14:54:46 CDT 2010
Hi Brian,
I've modified log_mpi_core.c to address this MPI_Pcontrol of MPI
communicator function within MPE.  Could you recompile MPE by
updating your log_mpi_core.c with
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/wrappers/src/log_mpi_core.c
and see if this solves your problem.
A.Chan
----- chan at mcs.anl.gov wrote:
> Hi Brian,
> MPE logging needs to know that the user program makes communicator
> creation calls, e.g. MPI_Comm_create/MPI_Comm_split/MPI_Comm_dup,....
> otherwise any subsequent MPI calls that uses these communicators
> can't be logged by MPE.  There is a mechanism in MPE that bypasses
> the actual logging but still keeps track of communicator
> creation/destruction.  It is likely the mechanism has bug.
> Do you have a small program that shows your use of communicators
> so I can make sure whatever fixes that I applied will solve your
> problem ?
> PS. Thanks for spending time to track down the problem.
> A.Chan
> ----- "Brian Wainscott" <brian at lstc.com> wrote:
> > I posted previously with the subject "MPE logging with OpenMPI"
> > describing some
> > issues I was having getting MPI_Pcontrol to work.  Anthony Chan
> > suggested I try
> > MPICH instead of OpenMPI, which I've finally had time to do.  It
> also
> > doesn't work.
> > I looked through the source code for mpe2, and suspect I know the
> > issue, and am
> > looking for help/confirmation/hopefully a fix or workaround:
> > According to these comments in log_mpi_core.c
> > (src/mpe2/src/wrappers/src):
> >  * MPI_Init checks for logging control options and environment
> > variables,
> >  * and MPI_Pcontrol allows control over logging (allowing the user
> to
> >  * turn logging on and off).  Note that some routines are ALWAYS
> > logged;
> >  * principly, these are the communicator constuction routines
> (needed
> > to
> >  * avoid using the "context_id" which may not exist in some MPI
> >  * implementations).
> > and this comment:
> >   level = 1 turns on tracing,
> >   level = 0 turns it off.
> >   Still to do: in some cases, must log communicator operations even
> > if
> >   logging is off.
> > int MPI_Pcontrol( const int level, ... )
> > I suspect the problem is related to a conflict with MPI_Pcontrol and
> > certain
> > communicator construction operations?
> > If tried modifying the problem I am running, in such a way that it
> > should not
> > create many (any?) communicators after initialization, and then
> > everything
> > behaves as I'd like: I can call MPI_Pcontrol(0) early on, and later
> > call
> > MPI_Pcontrol(1) then MPI_Pcontrol(0), and get one nice window into
> the
> > execution,
> > without a LOT of stuff I'm not interested in.
> > With my original problem, which does create communicators, I call
> > MPI_Pcontrol(0)
> > right after initialization, then MPI_Pcontrol(1) later, then
> > immediately get this
> > error:
> > clog_commset.c:CLOG_CommSet_get_IDs() -
> >         PMPI_Comm_get_attr() fails!
> > I tried putting calls to MPI_Pcontrol(1) just before (and
> > MPI_Pcontrol(0) just
> > after) every call to MPI_COMM_CREATE/MPI_COMM_DUP/MPI_COMM_FREE, but
> > that didn't
> > work (or maybe I missed one....)  Or maybe this is a red herring,
> and
> > the smaller
> > problem ran for some other unrelated reason.
> > Suggestions of anything else to try?
> > Does anyone know exactly WHICH calls must always be made?  It should
> > be a simple
> > matter to ignore the "is_mpilog_on" flag for just a few calls, if
> that
> > is all
> > that is needed....I just need to know WHICH ones.
> > Thanks!
> > Brian
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
