[mpich-discuss] Print the Timeline Window
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Thu Apr 22 09:39:15 CDT 2010
Joao,
The Print function in Jumpshot has yet been implemented, so you need to
use a screen dump program to print the Jumpshot's Timeline window.
For instance on Linux, say gnome, you can do "Alt-Print" to print the
window where your cursor is located and you can use "convert" the image
file to whatever format you like.
A.Chan
----- "Joao Duro" <j.a.duro at cranfield.ac.uk> wrote:
> Hi there,
> I am currently trying to print the Timeline of Jumpshot together with
> the events.
> What I want to achieve is something similar to the upshot output taken
> from [1].
> Desired Upshot Screenshot:
> http://imagebin.ca/view/hhrW0qH.html
> Accordingly to the Timeline Display Description from [2]:
>  ``Print'' allows for printing a Postscript version of the display.
> However my current Jumpshot has the "Print the Timeline Window" button
> disabled has it can be seen by the following screenshot.
> http://imagebin.ca/view/uA9Zdr.html
> Is Jumpshot able to give me the desired print?!
> In the end I would like to have a eps or jpg file which would
> definitely be added to a document.
> Regards,
> Joao
> [1] Using MPI-Portable Parallel Programming with the Message-Passing
> Interface, by William Gropp
> [2]
> http://www.mcs.anl.gov/research/projects/perfvis/software/viewers/jumpshot-2/node6.html
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
