[mpich-discuss] Error with more than 5 nodes
    Prashantha Hebbar
    prashantha.hebbar at manipal.edu
    Wed Apr 21 07:53:55 CDT 2010
Hi Friends,
I have come across  an error with mpdboot -n 6 -f mpd.hosts command.
Following is the error message
mpdboot_mlscubl3-desktop (handle_mpd_output 407): failed to handshake with
mpd on mlscubl11-desktop; recvd output={}
With mpdboot -n 5 -f mpd.hosts everything works fine. I also checked to
verify whether it is a problem with node, mlscubl11-desktop by keeping
mlscubl11-desktop alone in the mpd.hosts and executing mpdboot -n 2 -f
mpd.hosts. That  works fine. I have 15 nodes with me wherein
mlscubl3-desktop is master. There is no ssh problem. Somehow I have to
cluster all the 15. I tried in all the combination of nodes. But mpdboot
with more than 5 nodes not working properly.
Now my doubt is whether it is limitation of MPICH2 or linux (Ubuntu).  Can
you please help me to solve this?
Thanking you in anticipation.
Prashantha
Attention:
This e-mail message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.manipal.edu
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100421/9af5e173/attachment.htm>
