[mpich-discuss] Problems running mpi application on different CPUs
Rajeev Thakur
thakur at mcs.anl.gov
Sun Sep 27 18:29:24 CDT 2009
Try running on smaller subsets of the machines to debug the problem. It
is possible that a process on some machine cannot connect to another
because of some firewall settings.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Gaetano Bellanca
> Sent: Saturday, September 26, 2009 7:10 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Problems running mpi application on
> different CPUs
> Hi,
> I'm sorry but I posted with a wrong Object my previous message!!!
> I have a small cluster of
> a) 1 server: dual processor / quad core Intel(R) Xeon(R) CPU E5345
> b) 4 clients: single processor / dual core Intel(R) Core(TM)2
> Duo CPU E8400 connected with a 1Gbit/s ethernet network.
> I compiled mpich2-1.1.1p1 on the first system (a) and share
> mpich on the other computers via nfs. I have mpd running as a
> root on all the computers (ubunt 8.04 . kernel 2.6.24-24-server)
> When I run my code in parallel on the first system, it works
> correctly; the same happens running the same code in
> parallel on the other computers (always running the code from
> the server). On the contrary, running the code using
> processors from both the server and the clients at the same
> time with the command:
> mpiexec -machinefile machinefile -n 4 my_parallel_code
> I receive this error message:
> Fatal error in MPI_Init: Other MPI error, error stack:
> MPIR_Init_thread(394): Initialization failed
> (unknown)(): Other MPI error
> rank 3 in job 8 c1_4545 caused collective abort of all ranks
> exit status of rank 3: return code 1
> Should I use some particular flags in compilation or at run time?
> Regards.
> Gaetano
> Gaetano Bellanca - Department of Engineering - University of
> Ferrara Via Saragat, 1 - 44100 - Ferrara - ITALY Voice
> (VoIP): +39 0532 974809 Fax: +39 0532 974870
> mailto:gaetano.bellanca at unife.it
> L'istruzione costa? Stanno provando con l'ignoranza!
