[mpich-discuss] Problems running mpi application on different CPUs
Gaetano Bellanca
gaetano.bellanca at unife.it
Sat Sep 26 07:09:45 CDT 2009
I'm sorry but I posted with a wrong Object my previous message!!!
I have a small cluster of
a) 1 server: dual processor / quad core Intel(R) Xeon(R) CPU E5345
b) 4 clients: single processor / dual core Intel(R) Core(TM)2 Duo CPU
E8400
connected with a 1Gbit/s ethernet network.
I compiled mpich2-1.1.1p1 on the first system (a) and share mpich on the
other computers via nfs. I have mpd running as a root on all the
computers (ubunt 8.04 . kernel 2.6.24-24-server)
When I run my code in parallel on the first system, it works correctly;
the same happens running the same code in parallel on the other computers
(always running the code from the server). On the contrary, running the
code using processors from both the server and the clients at the same
time with the command:
mpiexec -machinefile machinefile -n 4 my_parallel_code
I receive this error message:
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(394): Initialization failed
(unknown)(): Other MPI error
rank 3 in job 8 c1_4545 caused collective abort of all ranks
exit status of rank 3: return code 1
Should I use some particular flags in compilation or at run time?
Regards.
Gaetano
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP): +39 0532 974809 Fax: +39 0532 974870
mailto:gaetano.bellanca at unife.it
L'istruzione costa? Stanno provando con l'ignoranza!
