[mpich-discuss] MPICH2 1.1a2 - problems with more than 4computers
Luiz Carlos da Costa Junior
lcjunior at ufrj.br
Wed Sep 23 17:10:23 CDT 2009
Hi Jayesh,
Thanks for your answer.
LC
2009/9/22 Jayesh Krishna <jayesh at mcs.anl.gov>
> Hi,
> From your reply it looks like your problem is the same as the one
> described in ticket 355. Try upgrading to a server edition of windows.
> (PS: We will include some code for retrying the network share conns -
> however upgrading to a server edition is your soln.)
> Regards,
> Jayesh
> *From:* lccostajr at gmail.com [mailto:lccostajr at gmail.com] *On Behalf Of *Luiz
> *Sent:* Tuesday, September 22, 2009 1:29 PM
> *To:* Jayesh Krishna
> *Cc:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] MPICH2 1.1a2 - problems with more than
> 4computers
> Hi Jayesh,
> My configuration is very similar to the Tina's (user in this ticket).
> I have 4 machines
> Intel(R) Core(TM)2 Quad CPU
> Q6600 @ 2.40GHz
> 8 GB of RAM
> running
> Microsoft Windows XP
> Professional x64 Edition
> Version 2003
> Service Pack 2
> over a Gigabit Network
> I run mpiexec with the following command:
> >> mpiexec.exe -configfile myconfigfile.txt
> myconfigfile.txt:
> -map j:\\computer1\paralell -n 1 -host computer1 -wdir j:\ j:\master
> -map j:\\computer1\paralell -n 4 -host computer1 -wdir j:\ j:\slave
> -map j:\\computer1\paralell -n 4 -host computer2 -wdir j:\ j:\slave
> -map j:\\computer1\paralell -n 4 -host computer3 -wdir j:\ j:\slave
> -map j:\\computer1\paralell -n 4 -host computer4 -wdir j:\ j:\slave
> And the error I get is:
> *********** Warning ************
> Unable to map \\computer1\paralell. (error 71)
> launch failed: CreateProcess(slave) on 'computer2' failed, error 2 - The
> syst
> em cannot find the file specified.
> launch failed: CreateProcess(slave) on 'computer3' failed, error 2
> - The system cannot find the file specified.
> launch failed: CreateProcess(slave) on 'computer4' failed, error 2 -
> syst
> unable to read the cmd header on the left context, Error = -1.
> Error posting readv, An existing connection was forcibly closed by the
> remote ho
> st.(10054)
> If I can provide you any further information, please let me know.
> Regards,
> LC
>> Hi,
>> The error that the ticket refers to is related to limitations (number of
>> network shares) of using a client version of windows.
>> Your problem may not be related to the ticket. Are you using network
>> shares ? What is the OS/ver that you use ? Please provide us as much details
>> as possible.
>> Regards,
>> Jayesh
>> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
>> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Luiz Carlos da Costa
>> Junior
>> *Sent:* Tuesday, September 22, 2009 9:56 AM
>> *To:* MPICH Discuss
>> 4computers
>> Dear all,
>> I got an error with MPICH2-1.1.1p1 and I found the following ticket that
>> describes exactly the error that I got:
>> http://trac.mcs.anl.gov/projects/mpich2/ticket/355
>> But I couldn't figure out which is the conclusion (or solution, if any)
>> for this error...
>> Could you please give me a clue?
>> Thanks,
>> LC
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090923/fac565b5/attachment.htm>
