[mpich-discuss] autoconf errors from svn code
Ashley Pittman
ashley at pittman.co.uk
Wed Sep 9 09:49:43 CDT 2009
All,
I'm trying to build MPICH2 from subversion but ./maint/updatefiles is
aborting with the following error. Is this a known problem and what can
I do to get around it?
I'm using r5309 on an up-to-date debian machine with autoconf 2.64.
Found ./src/binding/f90/configure.in; executing make configure target
(cd . && autoconf -I ../../../confdb )
configure.in:72: error: AC_LANG_CONFTEST: unknown language: Fortran 90
../../lib/autoconf/lang.m4:214: AC_LANG_CONFTEST is expanded from...
../../lib/autoconf/general.m4:2577: _AC_COMPILE_IFELSE is expanded
from...
../../lib/m4sugar/m4sh.m4:620: AS_IF is expanded from...
../../lib/autoconf/general.m4:2018: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2039: AC_CACHE_CHECK is expanded from...
../../../confdb/fortran90.m4:257: AC_PROG_F90 is expanded from...
../../../confdb/fortran90.m4:953: PAC_PROG_F90 is expanded from...
configure.in:72: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
make: *** [configure] Error 1
See /mnt/home/debian/ashley/code/mpich2/trunk/src/binding/f90/mf.tmp for
Makefile that failed
Error! Could not build configure in ./src/binding/f90 with make
configure
PANIC: Could not make configure from configure.in
In directory ./src/binding/f90
ashley at alpha:~/code/mpich2/trunk$
Ashley,
Ashley Pittman, Bath, UK.
Padb - A parallel job inspection tool for cluster computing
http://padb.pittman.org.uk
