[mpich-discuss] ch3:nemesis performance and SMP cluster
Vamvakopoulos Manolis evamvak at cs.uoi.gr
Sun Sep 6 11:12:23 CDT 2009
Dear Sir
1) I install mpich2-1.1.1p1  with default configuration .
and i use for test a application which user collective MPI routine (amber9)
and ,
The run with 16 proc on 16 node (16:1) was faster
than the same test with 8 nodes with 2 proc per node (again 16 proc)
i use osc mpiexec with --comm=mpich2-pmi
when i run the above tests normaly with mpd deamon as PM manager
and mpirun
everything are  fine and better .. the 8:2  is lightly faster
2.) Also , in previous version of mpich2  which I use
mpich2-1.0.8 the (osc) mpiexec 0.83 work with ch3:sock and ch3:ssm
the above tests (16:1) or (8:2) give comparable wall time
these is some way to work mpiexec 0.83 with ch3:nemesis communicator ?
thank you  in advance
best ev
E.v.
University OF Ioannina
Department of Computer Science
P.O. BOX 1186 Ioannina, Greece
Tel: (+30)-26510-98864
Fax: (+30)-26510-98890
Quoting Darius Buntinas <buntinas at mcs.anl.gov>:
> what error are you seeing when you use the osc mpiexec with mpich2 1.1.1p1?
> Thanks,
> -d
> On 09/06/2009 06:50 PM, Vamvakopoulos Manolis wrote:
> > Dear sir
> > as wrote the previous mail i forgot to refer
> > that i made my all test with "OSC mpiexec"
> > ( http://www.osc.edu/~djohnson/mpiexec/index.php )
> > which formal support ch3:sock as communication device over PMI
> > with MPICH2-1.1.1p1 LIB and mdp as a Proccess manager
> > the 8x2 tests on smp machine  it is OK over ch3:nemesis and it works fine!
> > the problem now is that mpiexec 0.83 (from OSC) it is not compatible
> > with the MPICH2-1.1.1p1 with nemesis communicator !!
> > best
> > E.V.
