[mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran Compiler(64 bit)
Dorian Krause
ddkrause at uni-bonn.de
Thu Sep 3 11:43:41 CDT 2009
Hi Steve,
just use
./configure –prefix=/home/sjberg/mpich –enable-f77 –enable-f90 (is this
correct?)
setting the CC, F77, ... variables should be sufficient for the
configure script to pick up the correct compiler.
You can use
./configure --help
to get a description of the flags ...
Steven Berg wrote:
> Hi Rajeev,
> When I try MPICH2-1.1.1p1 I can a configure error
> Configure: error: unrecognized option: -f90=ifort
> How do I specify the intel fortran compiler for MPICH2? Here are the
> commands I entered.
> #source /opt/intel/Compiler/11.1/046/bin/ifortvars.sh intel64
> #export CC=icc
> #export CXX=icpc
> #export F77=ifort
> #export FC=ifort
> #export F90=ifort
> #export RSHCOMMAND=ssh
> #./configure –prefix=/home/sjberg/mpich –enable-f77 –enable-F90modules
> –f90=ifort –cc=icc =c++=icpc –fc=ifort
> Steve
> *From:* mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Rajeev Thakur
> *Sent:* Thursday, September 03, 2009 12:19 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046
> Can you try the latest version of MPICH2 instead? MPICH-1 is too old.
> Rajeev
> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Steven Berg
> *Sent:* Thursday, September 03, 2009 9:32 AM
> *Subject:* [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046
> Hi All,
> I am currently trying to upgrade form 32-bit to 64-bit using Rocks
> Clusters 5.2. I previously had the 32-bit version installed on
> 64-bit machines and was able to get mpich1.2.7p1 to build
> (specifically mpif90). I was using the Intel Fortran Compiler
> 9.1.052 and the following commands
> #source /opt/intel/fc/9.1.052/bin/ifortvars.sh
> #export CC=icc
> #export CXX=icpc
> #export F77=ifort
> #export FC=ifort
> #export F90=ifort
> –enable-F90modules –f90=ifort –cc=icc =c++=icpc –fc=ifort
> #make
> #make install
> Using these commands I was able successfully build mpif90 and
> subsequently compile my code.
> Since upgrading to the 64-bit version of Rocks Clusters 5.2 and
> Intel Fortran Compiler 11.1.046 (64-bit install only) I am unable
> to get mpif90 to build using the following
> #export CC=icc
> #export CXX=icpc
> #export F77=ifort
> #export FC=ifort
> #export F90=ifort
> #make
> #make install
> I know I should be using Mpich2, but I was told I need to compile
> this code with mpich1.2.7p1. I am also fairly new to mpich and
> clustering, any advice or suggestions are greatly appreciated. I
> assume the problem has to do with the switch in intel compilers?
> Thanks in advance.
> Steve
> Steven J. Berg
> Ph.D. Student
> Physics 220C
> Department of Earth and Environmental Sciences
> University of Waterloo
> 200 University Ave.
> Waterloo, Ontario
> N2L 3G1
> 519 - 888 - 4567 x32738
> http://www.science.uwaterloo.ca/~sjberg/
> <http://www.science.uwaterloo.ca/%7Esjberg/>
