[mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran Compiler(64 bit)
Steven Berg
sjberg at uwaterloo.ca
Thu Sep 3 11:40:09 CDT 2009
Hi Rajeev,
When I try MPICH2-1.1.1p1 I can a configure error
Configure: error: unrecognized option: -f90=ifort
How do I specify the intel fortran compiler for MPICH2? Here are the
commands I entered.
#source /opt/intel/Compiler/11.1/046/bin/ifortvars.sh intel64
#export CC=icc
#export CXX=icpc
#export F77=ifort
#export FC=ifort
#export F90=ifort
#export RSHCOMMAND=ssh
#./configure -prefix=/home/sjberg/mpich -enable-f77 -enable-F90modules
-f90=ifort -cc=icc =c++=icpc -fc=ifort
Steve
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Thursday, September 03, 2009 12:19 PM
Subject: Re: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran
Compiler(64 bit)
Can you try the latest version of MPICH2 instead? MPICH-1 is too old.
Rajeev
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Steven Berg
Sent: Thursday, September 03, 2009 9:32 AM
Subject: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran
Compiler(64 bit)
Hi All,
I am currently trying to upgrade form 32-bit to 64-bit using Rocks Clusters
5.2. I previously had the 32-bit version installed on 64-bit machines and
was able to get mpich1.2.7p1 to build (specifically mpif90). I was using the
Intel Fortran Compiler 9.1.052 and the following commands
#source /opt/intel/fc/9.1.052/bin/ifortvars.sh
#export CC=icc
#export CXX=icpc
#export F77=ifort
#export FC=ifort
#export F90=ifort
#make
#make install
Using these commands I was able successfully build mpif90 and subsequently
compile my code.
Since upgrading to the 64-bit version of Rocks Clusters 5.2 and Intel
Fortran Compiler 11.1.046 (64-bit install only) I am unable to get mpif90 to
build using the following
#export CC=icc
#export CXX=icpc
#export F77=ifort
#export FC=ifort
#export F90=ifort
#make
#make install
I know I should be using Mpich2, but I was told I need to compile this code
with mpich1.2.7p1. I am also fairly new to mpich and clustering, any advice
or suggestions are greatly appreciated. I assume the problem has to do with
the switch in intel compilers?
Thanks in advance.
Steve
Steven J. Berg
Ph.D. Student
Physics 220C
Department of Earth and Environmental Sciences
University of Waterloo
200 University Ave.
Waterloo, Ontario
N2L 3G1
519 - 888 - 4567 x32738
http://www.science.uwaterloo.ca/~sjberg/
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090903/c27db66e/attachment.htm>
