[mpich-discuss] genvlist & map is not working in config file
Jayesh Krishna
jayesh at mcs.anl.gov
Thu Oct 29 10:04:23 CDT 2009
Does it work when you enter the command in the command line (without a config file) ? Have you set the environment variable CNTRL_MPI_DIR (Type "set" at the command prompt to see the list of environment variables set) in the shell environment used to launch the job ?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Thursday, October 29, 2009 9:59:12 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] genvlist & map is not working in config file
Hi Jayesh,
This is my config file.
In this sample MPICH2 does not launch the test.exe.
-host localhost -genvlist CNTRL_MPI_DIR,CNTRL_MPI_OUT -p 8676 -wdir <Working DIR> -path <pathDIR> test.exe -mpion -controller
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR1> test.exe -mpion -worker
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR2> test.exe -mpion -worker
However this is working :
-host localhost -env CNTRL_MPI_DIR d:\mpi -p 8676 -wdir <Working DIR> -path <pathDIR> product.exe -mpion -controller
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR1> product.exe -mpion -worker
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR2> product.exe -mpion -worker
In this sample mapping is not done on all the nodes. The workaround : I have to map network drive first manually and then use -mapall option on controller.
-host localhost -map z:\\abhishekp-xp\mpi\ -p 8676 -wdir <Working DIR> -path <pathDIR> test.exe -mpion -controller
Am I missing something in config file.
Abhishek
On Thu, Oct 29, 2009 at 8:11 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Can you send us a sample config file that does not work ?
Jayesh
Sent: Thursday, October 29, 2009 5:26:22 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] genvlist & map is not working in config file
On windows, I tried to use genvlist and map in mpi config file. ( mpiexec.exe -configfile <config file>).
But it is not working. Am I missing something ?
However -env and -mapall options are working in configfile. Also, I always have to set environment variables in configfile. Is there a way to just use the environment variables once it has been set on command line or in my-computer properties ?
Abhishek
mpich-discuss mailing list
