[mpich-discuss] genvlist & map is not working in config file
abhishek pandey
hipandey at gmail.com
Thu Oct 29 09:59:12 CDT 2009
Hi Jayesh,
This is my config file.
In this sample MPICH2 does not launch the test.exe.
-host localhost -genvlist CNTRL_MPI_DIR,CNTRL_MPI_OUT -p 8676 -wdir
<Working DIR> -path <pathDIR> test.exe -mpion -controller
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR1> test.exe
-mpion -worker
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR2> test.exe
-mpion -worker
However this is working :
-host localhost -env CNTRL_MPI_DIR d:\mpi -p 8676 -wdir <Working DIR> -path
<pathDIR> product.exe -mpion -controller
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR1> product.exe
-mpion -worker
-host localhost -p 8676 -wdir <Working DIR> -path <pathDIR2> product.exe
-mpion -worker
In this sample mapping is not done on all the nodes. The workaround : I
have to map network drive first manually and then use -mapall option on
controller.
-host localhost -map z:\\abhishekp-xp\mpi\ -p 8676 -wdir <Working DIR> -path
-mpion -worker
-mpion -worker
Am I missing something in config file.
Abhishek
On Thu, Oct 29, 2009 at 8:11 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
> Can you send us a sample config file that does not work ?
> Regards,
> Jayesh
> From: "abhishek pandey" <hipandey at gmail.com>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, October 29, 2009 5:26:22 AM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] genvlist & map is not working in config file
> Hi,
> On windows, I tried to use genvlist and map in mpi config file. (
> mpiexec.exe -configfile <config file>).
> But it is not working. Am I missing something ?
> However -env and -mapall options are working in configfile. Also, I always
> have to set environment variables in configfile. Is there a way to just use
> the environment variables once it has been set on command line or in
> my-computer properties ?
> Thanks,
> Abhishek
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091029/0e1ffac5/attachment-0001.htm>
