[mpich-discuss] installation problem
jayesh at mcs.anl.gov
Wed Oct 28 13:22:58 CDT 2009
Please find attached a zip file containing the MPICH2 1.2 libs/exes/dlls (32-bit). Please follow the instructions below to install MPICH2 manually using the zip file,
# Unzip the contents of zip file into "c:\program files\mpich2" folder.
# Copy the dll files in the lib folder to your system32 folder (copy c:\progra~1\mpich2\lib\*.dll c:\windows\system32).
# Install the process manager manually (smpd -install).
Let us know the results.
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Wednesday, October 28, 2009 1:07:02 PM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] installation problem
All the MPICH files are erased (uninstalled) when I click "OK" to the error message. The DLL is missing, as is smpd.
-----Original Message-----
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, October 28, 2009 11:55 AM
To: Gavron, Victor
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] installation problem
Can you manually install smpd now (smpd -install) ? Do you have mpich2mpi.dll installed in your system dir (dir c:\windows\system32\mpich2mpi.dll) ?
-Jayesh
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Wednesday, October 28, 2009 12:00:10 PM GMT -06:00 US/Canada Central
I made sure that it was not installed. I ran the command. At the end of the installation (the bar in the box was full) I got the same error message. Attached is the log file.
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, October 28, 2009 10:18 AM
To: Gavron, Victor
Please try the following,
# Make sure that you don't have MPICH2 installed on your system (pls look at the control panel)
# Download the latest MPICH2 installer (1.2) and perform a manual install with logging (msiexec /i mpich2-1.2-win-ia32.msi /log mpich2-1.2-ia32-install.log) and provide us with the log.
Jayesh
Sent: Wednesday, October 28, 2009 10:39:37 AM GMT -06:00 US/Canada Central
SP3 is installed, as well as all other Microsoft updates.
See the attached file for a screen dump of what happened when I tried smpd -install
Victor Gavron
Senior Advisor, LANSCE-DO,
MS-H845
505-667-5475
Foreign: TSPA
Sent: Wednesday, October 28, 2009 9:31 AM
Cc: Gavron, Victor
Do you have SP3 for XP installed on your machine ?
Can you try manually installing the process manager (smpd -install) and let us know the results ?
(PS: Please copy-paste the command and the output - don't retype the info in the email. This helps us in debugging the problem.)
Jayesh
Sent: Wednesday, October 28, 2009 10:26:41 AM GMT -06:00 US/Canada Central
I tried the latest version (2) that I downloaded. When that did not work, I downloaded older versions, starting at 1.07, and they did not install either.
This is Windows XP professional, updated with all existing patches.
I have Admin privileges. No previous version was installed.
Victor Gavron
MS-H845
505-667-5475
Foreign: TSPA
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Wednesday, October 28, 2009 9:14 AM
Cc: Francesca.Bottazzi at eni.it
Please provide us more information regarding your setup.
# Which version of MPICH2 are you installing (Try the latest stable version, 1.2, available at http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)?
# What is the flavor of windows installed in your machine (If you have windows vista installed you need to install the MPICH2 process manager manually - Open a command prompt with admin privileges, i.e. "run as administrator", and type "smpd -install -phrase behappy" to install MPICH2) ?
# Do you have another version of MPICH2 installed on your machine (If so, uninstall the prev version and install the new version)?
Jayesh
From: "Bottazzi Francesca" <Francesca.Bottazzi at eni.it>
Sent: Wednesday, October 28, 2009 5:16:40 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] installation problem
I’m trying to install MPICH2 on my pc (windows 32 bit) but it gives me the following message:
“There is a problem with this Windows Installer package.
A program run as a part of the setup did not finish as expected.
Contact your support personnel or package vendor.”
I can’t understand how to manage the problem…
Message for the recipient only, if received in error, please notify the sender and read http://www.eni.it/disclaimer/
mpich-discuss mailing list
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091028/bf95b356/attachment-0001.zip>
