[mpich-discuss] installation problem
Gavron, Victor
gavron at lanl.gov
Wed Oct 28 10:26:41 CDT 2009
I tried the latest version (2) that I downloaded. When that did not work, I downloaded older versions, starting at 1.07, and they did not install either.
This is Windows XP professional, updated with all existing patches.
I have Admin privileges. No previous version was installed.
Victor Gavron
Senior Advisor, LANSCE-DO,
MS-H845
505-667-5475
Foreign: TSPA
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Wednesday, October 28, 2009 9:14 AM
Cc: Francesca.Bottazzi at eni.it
Subject: Re: [mpich-discuss] installation problem
Please provide us more information regarding your setup.
# Which version of MPICH2 are you installing (Try the latest stable version, 1.2, available at http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)?
# What is the flavor of windows installed in your machine (If you have windows vista installed you need to install the MPICH2 process manager manually - Open a command prompt with admin privileges, i.e. "run as administrator", and type "smpd -install -phrase behappy" to install MPICH2) ?
# Do you have another version of MPICH2 installed on your machine (If so, uninstall the prev version and install the new version)?
Jayesh
----- Original Message -----
From: "Bottazzi Francesca" <Francesca.Bottazzi at eni.it>
Sent: Wednesday, October 28, 2009 5:16:40 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] installation problem
I’m trying to install MPICH2 on my pc (windows 32 bit) but it gives me the following message:
“There is a problem with this Windows Installer package.
A program run as a part of the setup did not finish as expected.
Contact your support personnel or package vendor.”
I can’t understand how to manage the problem…
Message for the recipient only, if received in error, please notify the sender and read http://www.eni.it/disclaimer/
mpich-discuss mailing list
