[mpich-discuss] General Scalability Question
Robertson, Andrew andrew.robertson at atk.com
Mon Oct 26 10:30:24 CDT 2009
Folks,
Our IT staff is not particularly knowledgeable about parallel computing.
Their current upgrade plan centers around quad/quad or dual/hex boxes
which would have 16 or 12 cores respectively. I have no doubt that such
a machine would run a parallel job efficiently. My question is how well
can I harness multiple boxes together?
The applications are all CFD (FLUENT, GASP, STAR, VULCAN). I am talking
to the various software vendors about this but would like some info from
the programming community.
Assuming the same memory per core am I better off with
High core count (12-16) boxes on a gigabit switch
Lower core count (2 -4) boxes on an infiniband switch.
I understand that if I configure mpich correctly it will use shared
memory on the mutli-core multi-processor boxes. If I end up with the
high core count boxes, should I spec the frontside bus (or whatever it
is called now) as high as possible??
I also have concerns that a single power supply failure takes out more
cores, though perhaps that is not such a problem
Any information is greatly appreciated
Thanks
Andy
Andrew Robertson P.E.
CFD Analyst
GASL Operations
Tactical Propulsion and Controls
ATK
77 Raynor Avenue
Ronkokoma NY 11779
631-737-6100 Ext 120
Fax: 631-588-7023
www.atk.com
!! Knowledge and Thoroughness Baby !!
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091026/190020bf/attachment.htm>
