[mpich-discuss] problem on mpich
JAY jameslipd at gmail.com
Tue Oct 20 03:55:31 CDT 2009
Dear Rajeev
Thank you for the prompt reply. The problems have been solved.
On Tue, Oct 20, 2009 at 4:14 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>  The install directory that you specify in the --prefix option to
> configure must be different from the directory where you are compiling the
> source.
> Separately, I would recommend using MPICH2 instead of MPICH 1.2.7, which is
> very old.
> Rajeev
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *JAY
> *Sent:* Tuesday, October 20, 2009 2:51 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [mpich-discuss] problem on mpich
> Dear all
> I am new to linux, here I met a problem when I compile mpich-1.2.7 on FC10.
> My system environment is:
> gcc version 4.4.1 (GCC)
> pgf90 7.0-5 64-bit target on x86-64 Linux
> The problem is
>  if [ "" = "" ] ; then \
>         ./bin/mpiinstall  ; \
>     else \
>         ./bin/mpiinstall -prefix=  ; \
>     fi
> cp: `/home/jy/espresso/mpich-1.2.7p1/bin/tarch' and
> `/home/jy/espresso/mpich-1.2.7p1/bin/tarch' are the same file
> **Error copying file /home/jy/espresso/mpich-1.2.7p1/bin/tarch to
> /home/jy/espresso/mpich-1.2.7p1/bin/tarch **
> make: *** [install] Error 1
> I met this problem when I type in make install. What's wrong with it? Thank
> you in advance.
> Sincerely
> Jiaye
> mpich-discuss mailing list
Sincerely
Jiaye
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091020/46160cf6/attachment.htm>
