[mpich-discuss] Fwd: Problem with mpich2 install
Marin Vila
rinmalavi at gmail.com
Mon Oct 19 19:48:06 CDT 2009
thx a lot, this worked.
Instaling cpp was also a requirement
2009/10/19 Anthony Chan <chan at mcs.anl.gov>:
> Your configure.log indicated that you were using mpich2-1.0
> which seems to abort when no valid fortran compiler is found.
> Please download the latest version of mpich2, currently at 1.2,
> which should not have this problem.
> A.Chan
> ----- "Marin Vila" <rinmalavi at gmail.com> wrote:
>> ---------- Forwarded message ----------
>> From: Marin Vila <rinmalavi at gmail.com>
>> Date: 2009/10/19
>> Subject: Problem with mpich2 install
>> To: mpich2-maint at mcs.anl.gov
>> Must say I`m relatively new to linux(ubuntu), so i might miss on
>> something.
>> I was following steps in your install manual with modifications to
>> paths involved.
>> In step 4 I get:
>> bash: syntax error near unexpected token `&'
>> so I use it without it
>> at step 5:
>> Same problem, I do the same modification.
>> and :
>> make: *** Nijedna meta nije navedena, niti je ijedan makefile
>> pronađen. Zaustavi.
>> eng: None of the targets indicated, not one makefile found. Stop.
>> Thank you
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
