[mpich-discuss] Fwd: Problem with mpich2 install
Anthony Chan chan at mcs.anl.gov
Mon Oct 19 15:48:32 CDT 2009
Your configure.log indicated that you were using mpich2-1.0
which seems to abort when no valid fortran compiler is found.
Please download the latest version of mpich2, currently at 1.2,
which should not have this problem.
A.Chan
----- "Marin Vila" <rinmalavi at gmail.com> wrote:
> ---------- Forwarded message ----------
> From: Marin Vila <rinmalavi at gmail.com>
> Date: 2009/10/19
> Subject: Problem with mpich2 install
> To: mpich2-maint at mcs.anl.gov
> Must say I`m relatively new to linux(ubuntu), so i might miss on
> something.
> I was following steps in your install manual with modifications to
> paths involved.
> In step 4 I get:
> bash: syntax error near unexpected token `&'
>  so I use it without it
> at step 5:
> Same problem, I do the same modification.
> and :
> make: ***  Nijedna meta nije navedena, niti je ijedan makefile
> pronađen.  Zaustavi.
> eng: None of the targets indicated, not one makefile found. Stop.
> Thank you
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
