[mpich-discuss] Anyluck Luck with PGI Compilers for MPICH2-1.2?
Capehart, William J
William.Capehart at sdsmt.edu
Sun Oct 18 12:04:49 CDT 2009
> Message: 8
> Date: Sun, 18 Oct 2009 11:30:20 -0500
> From: Dave Goodell <goodell at mcs.anl.gov>
> Subject: Re: [mpich-discuss] Anyluck Luck with PGI Compilers for
> MPICH2-1.2?
> To: mpich-discuss at mcs.anl.gov
> Message-ID: <1AEBE2A2-89AC-466D-968C-4F3A7A38EFC3 at mcs.anl.gov>
> Content-Type: text/plain; charset=WINDOWS-1252; format=flowed;
> delsp=yes
> On Oct 18, 2009, at 10:42 AM, Capehart, William J wrote:
>> Has anyone had any traction getting MPICH2 to compile with ch3
>> nemesis (as opposed to socks) on the PGI compiler set? I?ve had no
>> luck (except for doing it with socks) with the Linux 32&64 and the
>> MacOS versions of PGI.
> I'm not 100% certain of the current status of Nemesis+PGI. Nemesis
> depends on the OPA library in order to get atomic assembly
> instructions for some of the shared memory communication. At least as
> of a while ago, OPA still didn't work on PGI because of some bugs in
> the PGI compiler itself.
> Darius might know the status with greater certainty. If not, I can
> play with it on Monday or Tuesday and get back to you to see where we
> are at w.r.t. PGI.
> What version of the compiler are you using? If things are going to
> work at all, you'll probably need a fairly recent version. We have
> 7.1 and 8.0.5 here at ANL, and I'm fairly certain that it will not
> work with 7.x, but I'm not sure about 8.x. And I haven't used the 9.x
> series yet at all. I just tried to test things with 8.x, but our
> license server is having some trouble after a datacenter move this
> weekend. I'll let you know more once we get that sorted out this week.
> -Dave
Hi Dave
I’m running the 9.0-4 on both linux (mandriva and fedora, both 32 and 64) and on the mac with both leopard and snowleopard.
Like I said, I can still get it to compile with socks...
Thanks
Bill
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091018/198fe08a/attachment.htm>
