[mpich-discuss] Can ch3:nemesis:mx use both MX and TCP networks ?
Guillaume Mercier
mercierg at mcs.anl.gov
Tue Oct 13 12:05:24 CDT 2009
Hello Martin,
Audet, Martin a écrit :
> MPI_Users/MPI_Developers,
> I always thought (but never tested) that the ch3:nemesis:mx cmehannel
> has the ability to independently select either MX or TCP to
> communicate between any pair of MPI processes when shared memory
> communication isn’t possible (e.g. the two process run on different
> nodes).
When Nemesis:Mx is selected, only MX can be used.
> However after carefully reading the README file, I fear mpich2 doesn’t
> have this flexibility that is, network communication with the
> ch3:nemesis:mx channel is always done using MX (of course network
> communication occurs when shared memory communication isn’t possible).
Your interpretation is right.
> When shared memory communication isn’t possible, does the
> ch3:nemesis:mx channel has the ability to independently select either
> MX or TCP to communicate between two MPI processes ?
The Mx module does not offer this kind of possibility. Could you explain
to me when shared memory is not possible within
a node ? I don't see the case.
Guillaume
