[mpich-discuss] mpich2 configure error
Anthony Chan chan at mcs.anl.gov
Wed Nov 25 10:04:54 CST 2009
Did you try:
mpd &
mpiexec -n 4 cpilog
A.Chan
----- "Nesan Antonyraj" <Gnananesan-Antonyraj at utc.edu> wrote:
> Everything worked out well.  I can compile C code using mpicc/mpic++.
> Since I have installed this on my laptop, I don't know how to make use
> of it to test MPI code.  Please help if there is any way to simulate
> multiprocessor platform.
> Thanks to Mr. Balaji for his expertise in providing the fixes.
> Nesan.
> -----Original Message-----
> From: Pavan Balaji <balaji at mcs.anl.gov>
> To: Gnananesan-Antonyraj at utc.edu
> Date: Tue, 24 Nov 2009 21:10:45 -0600
> Subject: Re: [mpich-discuss] mpich2 configure error
> You are trying to install it into the same location where you built
> it.
> So, "make install" is not able to copy the files correctly. You
> should
> use a different install path with --prefix=c:/mpich2-install
>  -- Pavan
> On 11/24/2009 09:08 PM, Nesan Antonyraj wrote:
> > The configure and make steps completed successfully.  'make install'
>  got one error.  Attached is the mi.txt output file.  Please check and
> advise.
> > thanks,
> > Nesan.
> > Date: Tue, 24 Nov 2009 20:00:23 -0600
> > Hmm.. It looks like you have clock_gettime on your system, but it's
> not
> > a part of librt.a. This is partly an error in configure itself,
> which
> > I'll poke into.
> > In the meanwhile, can you configure with
> > --enable-timer-type=gettimeofday and see if that gets you past this
> problem?
> > Alternatively, we provide windows binaries on our website:
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> > if you want to use those instead.
> >  -- Pavan
> > On 11/24/2009 07:49 PM, Nesan Antonyraj wrote:
> >> Thanks Mr. Balaji.  Attached is the configure output text c.txt.  I
> am configuring within cygwin with the command,
> >> c:/nesan/libraries/mpich2-1.2.1/configure -prefix=c:/build 2>&1 |
> tee c.txt
> >> thanks,
> >> Nesan.
> >> To: Gnananesan-Antonyraj at utc.edu, mpich-discuss at mcs.anl.gov
> >> Date: Tue, 24 Nov 2009 19:45:38 -0600
> >> Can you send us the entire configure output? It's very hard to say
> what
> >> the problem is based on just the below information.
> >>     for csh and tcsh:
> >>       ./configure --prefix=/home/you/mpich2-install |& tee c.txt
> >>     for bash and sh:
> >>       ./configure --prefix=/home/you/mpich2-install 2>&1 | tee
> c.txt
> >>  -- Pavan
> >> On 11/24/2009 07:42 PM, Nesan Antonyraj wrote:
> >>> Hello,
> >>> I am getting the error below when configuring mpich2-1.2.1.
> Please advise.
> >>> configure: error: Requested timer clock_gettime (POSIX) is not
> available
> >>> thanks,
> >>> Nesan.
> >>> _______________________________________________
> >>> mpich-discuss mailing list
> >>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
