[mpich-discuss] Building the HP-UX MPICH library --Question
Hirsh, Joel E
joel.e.hirsh at boeing.com
Wed Nov 25 09:03:19 CST 2009
I tried downloading as described below. Thr file comes across as mpich2-1.2.1.tar.tar. I renamed it to mpich2-1.2.1.tar.gz
I do have gnu tar version 1.1.2 (I think). The tar command appeared to do nothing as did the zcat command piped into tar. I tried the zcat command alone but the screened scrolled too fast for me to read it and then the PC crashed. I can try it on a UNIX machine and see what happens.
Joel E. Hirsh Ph.D.
Boeing Research and Technology
PO BOX 16858, MC P29-99
Philadelphia, PA
Office: 610-591-7769
Cell: 610-517-1098
Fax: 314-545-8651
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius Buntinas
Sent: Tuesday, November 24, 2009 12:24 PM
Subject: Re: [mpich-discuss] Building the HP-UX MPICH library --Question
Did you download it from here?
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.2.1/mpich2-1.2.1.tar.gz
If you have gnu tar (do a tar --version to find out), untar it like this:
tar zxf mpich2-1.2.1.tar.gz
If you don't have gnu tar, you'll have to uncompress it first, then untar:
zcat mpich2-1.2.1.tar.gz | tar xf -
Let us know how that works for you.
-d
On 11/24/2009 11:09 AM, Hirsh, Joel E wrote:
> I downloaded the latest MPICH2 source code, but I am unable to access it. I get a checksum error using tar on the UNIX machine and Winzip doesn't like it on a PC. Any suggestions?
> Joel E. Hirsh Ph.D.
> Philadelphia, PA
> Cell: 610-517-1098
> Fax: 314-545-8651
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Hirsh, Joel E
> Sent: Monday, November 23, 2009 5:53 PM
> To: Anthony Chan; mpich-discuss at mcs.anl.gov
> I believe our application uses very plain FORTRAN interfaces to MPI and therefore it should be OK. Assuming I get this application built, is there any learning curve for running the application? I believe we used the mpirun command and a list of nodes.
> Thanks,
> Joel E. Hirsh Ph.D.
> Boeing Reaearch and Technology
> Philadelphia, PA
> Cell: 610-517-1098
> Fax: 314-545-8651
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony Chan
> Sent: Monday, November 23, 2009 5:32 PM
> I would say you should try MPICH2 first. MPICH-1 has not been developed
> for years so its support for newer compilers is questionable.
> You can try building MPICH2 with new HP compilers (and send us your
> configure and make outputs if there is any problem.) and see if the mpich2
> library works with your F77 code. If your app does not use any MPICH-1
> implementation specific features, MPICH2 should be OK with your app.
> A.Chan
> ----- "Joel E Hirsh" <joel.e.hirsh at boeing.com> wrote:
>> Some advice please!
>> We have an application that uses MPICH-1 on HP-UX. We built the MPICH
>> library back in 1999 using MPICH-1.1.1. Today, we cannot link to it,
>> probably because the newer HP compilers are no compatible with that
>> old library. Our application is basically a FORTRAN 77 code.
>> In order to bring us up to date, I believe we need to have a current
>> version of the MPICH library for HP-UX. Should we build the HP-UX
>> library from the latest MPICH-1 source as we did a long time ago, or
>> should we jump to MPICH-2? If we go to MPICH-2, is there an HP-UX
>> library that we can use without building the library ourselves?
>> Thank you
>> Joel E. Hirsh Ph.D.
>> Philadelphia, PA
>> Cell: 610-517-1098
>> Fax: 314-545-8651
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
