[mpich-discuss] Building the HP-UX MPICH library --Question
Hirsh, Joel E joel.e.hirsh at boeing.com
Mon Nov 23 16:52:47 CST 2009
I believe our application uses very plain FORTRAN interfaces to MPI and therefore it should be OK.  Assuming I get this application built, is there any learning curve for running the application?  I believe we used the mpirun command and a list of nodes.
Joel E. Hirsh Ph.D.
Boeing Reaearch and Technology
PO BOX 16858, MC P29-99
Philadelphia, PA
Office: 610-591-7769
Cell: 610-517-1098
Fax: 314-545-8651
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony Chan
Sent: Monday, November 23, 2009 5:32 PM
Subject: Re: [mpich-discuss] Building the HP-UX MPICH library --Question
I would say you should try MPICH2 first.  MPICH-1 has not been developed
for years so its support for newer compilers is questionable.
You can try building MPICH2 with new HP compilers (and send us your
configure and make outputs if there is any problem.) and see if the mpich2
library works with your F77 code.  If your app does not use any MPICH-1
implementation specific features, MPICH2 should be OK with your app.
A.Chan
----- "Joel E Hirsh" <joel.e.hirsh at boeing.com> wrote:
> Some advice please!
> We have an application that uses MPICH-1 on HP-UX.  We built the MPICH
> library back in 1999 using MPICH-1.1.1.  Today, we cannot link to it,
> probably because the newer HP compilers are no compatible with that
> old library.  Our application is basically a FORTRAN 77 code.
> In order to bring us up to date, I believe we need to have a current
> version of the MPICH library for HP-UX.  Should we build the HP-UX
> library from the latest MPICH-1 source as we did a long time ago, or
> should we jump to MPICH-2?  If we go to MPICH-2, is there an HP-UX
> library that we can use without building the library ourselves?
> Thank you
> Joel E. Hirsh Ph.D.
> Philadelphia, PA
> Cell: 610-517-1098
> Fax: 314-545-8651
> mpich-discuss mailing list
