[mpich-discuss] HELP PLEASE
Jayesh Krishna jayesh at mcs.anl.gov
Mon Nov 23 08:57:30 CST 2009
 Install MPICH2 on all the nodes of the cluster. Make sure that the firewall is turned off (If you want to run MPICH2 using the windows firewall see the windows developers guide - available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs - for details).
 Now run your MPI job using a machine file (mpiexec -n 2 -machinefile mf.txt myMPIprogram.exe ; where the machinefile, mf.txt, contains the ipaddresses of the nodes).
 Let us know if you have any problems.
Jayesh
----- Original Message -----
From: "Rodinei Nunes" <rodinei.nunes at yahoo.com.br>
Sent: Sunday, November 22, 2009 11:38:05 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] HELP PLEASE
Hi, I would use the MPICH program but had difficulty understanding how to
set up would be able to help you send the configuration on each machine to
run on cluster computers? Both connected by a cable CAT6 CROSSOVER 1GB and
the computer's IP is 1.1.1.1 MSI mask 255.0.0.0 name of the computer
network MSI, the ASUS 1.1.1.1.2 IP mask 255.0.0.0 name of the computer
network ASUS
I have a program for editing the Avid Liquid Edition and your executable
is named studiomu and would like to use it in CLUSTER please what are the
settings and how to install MPICH program so I can use the performance of
computers together, Setup MSI 975 Platinum Pentium D dual core 2.8Ghz
Intel 975 chipset and ASUS Pentium D dual core 3.0Ghz Intel X48 chipset all windows XPSP3.
Please look forward, grateful
Rodinei
 Nunes
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
mpich-discuss mailing list
