[mpich-discuss] [mpich2-dev] About WMPICONFIG
Jayesh Krishna jayesh at mcs.anl.gov
Wed Nov 18 09:53:21 CST 2009
 Install the same version of MPICH2 on all the machines and you should be good to go (Make sure that all the machines have the same data model - all are x64 machines or all are ia32 machines). Also make sure that the firewalls are turned off on all the machines (or look into the windows developer's guide - available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs - for info on how to config MPICH2 with windows firewall)
 Let us know if it works for you.
(PS: mpich-discuss would be the right mailing list for your emails)
Jayesh
----- Original Message -----
To: mpich2-dev at mcs.anl.gov
Sent: Wednesday, November 18, 2009 5:18:59 AM GMT -06:00 US/Canada Central
Subject: [mpich2-dev] About WMPICONFIG
Hello,Can I config MPI in command line? I want to get the computers which has installed MPICH2 in the loacl area web .My OS is Windows XP. My English is poor, I don't know if I express the problem exactly.
