[mpich-discuss] mpd...fialed..
hailong.yang1115
hailong.yang1115 at gmail.com
Mon Nov 16 08:46:20 CST 2009
Which user are you using when you run mpd? If it is an ordinary user, you should have a .mpd.conf file under the home directory like the following:
cd $HOME
touch .mpd.conf
chmod 600 .mpd.conf
and the .mpd.conf file contains a single line:
secretword=<secretword>
which should be the same on the machines you want run into a ring.
If it is the root user, you should make a file named mpd.conf under the /etc directory. And the contents are the same as the former.
-Hailong
2009-11-16
* Hailong Yang, PhD. Candidate
* Sino-German Joint Software Institute,
* School of Computer Science&Engineering, Beihang University
* Phone: (86-010)82315908
* Email: hailong.yang1115 at gmail.com
* Address: G413, New Main Building in Beihang University,
* No.37 XueYuan Road,HaiDian District,
* Beijing,P.R.China,100191
发件人: Zain elabedin hammade
发送时间: 2009-11-16 21:50:17
收件人: MPICH2 Forum
抄送:
主题: [mpich-discuss] mpd...fialed..
Hello All.
I am sorry for the empty message that I have sent by mistake .
I have a cluster with 4 machines (fedora core 11).
I installed mpich2 - 1.1.1-1.fc11.i586.rpm .
I wrote on every machine :
mpd &
mpdtrace -l
then i wrote on thr Master :
mpd -h Worker1.cluster.net - p 56128 -n
I got :
Master.cluster.net_38047 (connect_lhs 944): NOT OK to enter ring; one likely cause: mismatched secretwords
Master.cluster.net_38047 (enter_ring 873): lhs connect failed
Master.cluster.net_38047 (run 256): failed to enter ring
And the same was for other machines : Worker2 and Worker3 .
For information :
I have SSH works on ..
So where is the problem ?
What i have to do ?
I really need your help .
Regarded .
Windows Live: Make it easier for your friends to see what you’re up to on Facebook.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091116/c7167d67/attachment.htm>
