[mpich-discuss] Problems with starting mpd
    hailong.yang1115
    hailong.yang1115 at gmail.com
    Sat Nov 14 22:21:11 CST 2009
Hi Dave,
I changed the first line in the installed mpd script to the following:
#!/usr/bin/env python2.4
And it worked!
Thank you for your reply.
-Hailong
2009-11-15
* Hailong Yang, PhD. Candidate
* Sino-German Joint Software Institute,
* School of Computer Science&Engineering, Beihang University
* Phone: (86-010)82315908
* Email: hailong.yang1115 at gmail.com
* Address: G413, New Main Building in Beihang University,
*              No.37 XueYuan Road,HaiDian District,
*              Beijing,P.R.China,100191
发件人: Dave Goodell
发送时间: 2009-11-15  10:06:46
收件人: mpich-discuss
抄送:
主题: Re: [mpich-discuss] Problems with starting mpd
MPD is not currently compatible with python 2.2.  Using a newer (2.x)
version of python should solve this problem.  Depending on how you
upgraded to the newer version, the mpd scripts may still be using your
older version of python.  Check the shebang line at the top of the
installed python script and make sure that it makes sense, and check
that the upgraded python is in your path.  You will probably need to
rebuild MPICH2 after upgrading your python installation to make sure
that it picks up the new version.  If it still auto-detects the wrong
python installation, you can help it pick the right one by passing "--
with-python=/path/to/python" to configure.
-Dave
On Nov 13, 2009, at 10:42 PM, hailong.yang1115 wrote:
> Hi there,
> I have recently installed mpich2-1.2 on RedHat SL 3. After that I
> started the mpd, which gave me the following error:
> [root at jsiserver112 root]# mpd &
> [1] 1797
> [root at jsiserver112 root]# Traceback (most recent call last):
>   File "/usr/local/mpich2-1.2/bin/mpd", line 87, in ?
>     from sets import Set as set
> ImportError: No module named sets
> [1]+  Exit 1                  mpd
> I googled to find that maybe it was incompatible with the older
> version of Python 2.2. So I changed to version 2.4 and version
> 3.1.1(most recently) but still got the same error.
> Looking for any help.
> -Hailong
> 2009-11-14
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091115/9f2cf1a8/attachment.htm>
