[mpich-discuss] Problems with starting mpd
Dave Goodell goodell at mcs.anl.gov
Sat Nov 14 20:06:23 CST 2009
MPD is not currently compatible with python 2.2.  Using a newer (2.x)
version of python should solve this problem.  Depending on how you
upgraded to the newer version, the mpd scripts may still be using your
older version of python.  Check the shebang line at the top of the
installed python script and make sure that it makes sense, and check
that the upgraded python is in your path.  You will probably need to
rebuild MPICH2 after upgrading your python installation to make sure
that it picks up the new version.  If it still auto-detects the wrong
python installation, you can help it pick the right one by passing "--
with-python=/path/to/python" to configure.
-Dave
On Nov 13, 2009, at 10:42 PM, hailong.yang1115 wrote:
> Hi there,
> I have recently installed mpich2-1.2 on RedHat SL 3. After that I
> started the mpd, which gave me the following error:
> [root at jsiserver112 root]# mpd &
> [1] 1797
> [root at jsiserver112 root]# Traceback (most recent call last):
>   File "/usr/local/mpich2-1.2/bin/mpd", line 87, in ?
>     from sets import Set as set
> ImportError: No module named sets
> [1]+  Exit 1                  mpd
> I googled to find that maybe it was incompatible with the older
> version of Python 2.2. So I changed to version 2.4 and version
> 3.1.1(most recently) but still got the same error.
> Looking for any help.
> -Hailong
> 2009-11-14
> * Hailong Yang, PhD. Candidate
> * Sino-German Joint Software Institute,
> * School of Computer Science&Engineering, Beihang University
> * Phone: (86-010)82315908
> * Email: hailong.yang1115 at gmail.com
> * Address: G413, New Main Building in Beihang University,
> *              No.37 XueYuan Road,HaiDian District,
> *              Beijing,P.R.China,100191
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
