[mpich-discuss] Problems with configuring MPICH with cross compiler
chan at mcs.anl.gov
chan at mcs.anl.gov
Wed Nov 11 17:08:17 CST 2009
It looks like the test for MPI_Offset at the end of top-level configre.in
broke the cross-compile support in MPICH2. Can you file a bug report at
mpich2-maint at mcs.anl.gov and send in your config.log and tee.txt
as well as your configure command that failed ?
There is a distclean target in Makefile but since configure
failed so no Makefile was created, i.e. no need to do "make distclean".
(I should have seen this earlier)
If your don't need MPI-IO, i.e. romio, you can try the following to
see if the configure completes:
./configure --prefix=/home/junligu/shared/MPICH_alpha2
--enable-cxx --disable-f77 --disable-romio
--with-device=ch3:nemesis --with-atomic-primitives=no
--build=i386-unknown-linux-gnu --host=alpha-unknown-linux-gnu
Let us know how it goes.
A.Chan
----- "junli gu" <gujunli at gmail.com> wrote:
> Thank you very much for help!
> I did as you said. But the problem keeps the same. I have attached
> the
> output of configuring process in tee.txt . the the other information
> is in
> config.log.
> By the way waht do you mean by "make dist clean"? I tried but there is
> make:
> *** No rule to make target `distclean'. Stop.
> I hope you can look to it further. Thank you !
> 2009/11/11 <chan at mcs.anl.gov>
> > > "export
> DRIVER_PATH=/opt/crosstool/gcc-3.4.3-glibc-2.3.5/alpha-unknown-linux-gnu/alpha-unknown-linux-gnu/
> > > export GCC=${DRIVER_PATH}/bin/alpha-gcc
> > > export CC=${DRIVER_PATH}/bin/alpha-gcc
> > > export CXX=${DRIVER_PATH}/bin/g++
> > > export AR=${DRIVER_PATH}/bin/ar
> > > export LD=${DRIVER_PATH}/bin/ld
> --enable-cxx
> > > --disable-f77 --with-device=ch3:nemesis
> > > --target=alpha-unknown-linux-gnu --host=i386-unknown-linux-gnu "
> > It seems you might have specified --host incorrectly, replace
> > your --host and --target options by the followings:
> > (see
> http://www.gnu.org/software/autoconf/manual/autoconf.html#Specifying-Target-Triplets
> > Be sure to do a "make distclean" before reconfiguring mpich2.
> > If the problem persists, send us the configure and make outputs
> > as seen on your terminal (It is possible that cross-compile support
> > is still buggy)
> > BTW, your stderr message should be piped to the configure output
> > file as it will help us to identify any potential problem/bug
> faster.
> > If you are not familiar with piping stderr and stdout to 1 file,
> > see the mpich2's README or installer's guide.
> > A.Chan
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Gu Junli--谷俊丽
> PHD Candidate of Tsinghua University
> Beijing 100084,China
> Tel: 86-10-62795139
