[mpich-discuss] Facing problem while using MPI_File_set_view
Wei-keng Liao
wkliao at ece.northwestern.edu
Fri May 29 23:38:17 CDT 2009
Hi, Christina,
Can you try the following temporary fix? I believe there is a bug
in adio/ad_pvfs2/ad_pvfs2_read.c, line 477. Please replace
file_lengths[0] = st_frd_size;
with
file_lengths[0] = ADIOI_MIN(st_frd_size, bufsize);
I tested you program with this fix and it ran fine.
(I used mpich2-1.0.8p1)
Wei-keng
On May 28, 2009, at 1:28 PM, Christina Patrick wrote:
> Yeah sure. Please go ahead.
> In case you'll are able to figure out where the problem lies, please
> do let me know so that I can download the patch.
> Also, could you please tell me how to download the CVS version? And,
> is the problem going away with the latest mpich CVS or pvfs CVS
> versions?
> Thanks and Regards,
> Christina.
> On Thu, May 28, 2009 at 8:43 AM, Rob Latham <robl at mcs.anl.gov> wrote:
>> On Wed, May 27, 2009 at 06:04:28PM -0400, Christina Patrick wrote:
>>> Thank you very much. Since the API MPI_Type_create_subarray() is
>>> very
>>> easy to use as compared to other API's used to create data types in
>>> MPI, I would really appreciate a solution to this problem.
>>> FYI: I am using pvfs 2.8.0.
>>> I will check it out with pvfs2.8.1 and keep you posted.
>> I think 2.8.1 will also crash. You will probably have to download
>> the
>> CVS version if you want things to work right now. We can work on
>> figuring out just what changed between 2.8.1 and recent CVS.
>> Can we add your program to the PVFS testsuite?
>> ==rob
>> Rob Latham
>> Mathematics and Computer Science Division
>> Argonne National Lab, IL USA
