[mpich-discuss] MPICH2 Support On Windows HPC Server 2008
Larry Adams ladams at platform.com
Thu May 21 16:54:18 CDT 2009
Its likely around security model.  If you look at how delegation works, on a per host basis, it has changed dramatically.
The constraining of services used to be available through the registry and the available authentication types I don't believe existed.
That's why my guess is authentication.  However, the function binds and then searches, which is working, but only by name.
Looks like your on it though.
Larry
-----Original Message-----
To: Larry Adams
CC: mpich-discuss at mcs.anl.gov <mpich-discuss at mcs.anl.gov>
Sent: Thu May 21 17:45:41 2009
Subject: RE: [mpich-discuss] MPICH2 Support On Windows HPC Server 2008
  DsMakeSpn() is called with a NULL ServiceName and according to the MSDN docs the ServiceName should be non-NULL (As you mentioned in your prev email this could be something that has changed over time).
 GetGCSearch() fails with error "ERROR_INVALID_FUNCTION"... Interesting...
Jayesh
  _____
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Wednesday, May 20, 2009 10:55 AM
To: 'Larry Adams'
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] MPICH2 Support On Windows HPC Server 2008
  Thanks for your input. I will look into this and get back to you today.
Jayesh
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Larry Adams
Sent: Wednesday, May 20, 2009 7:12 AM
Jayesh,
Sorry for the delay.  Register spn works fine and nothing works relative to delegation in 2008 HPC.  From the service principal perspective, we are able to see the service principal registered in Active Directory just fine after running the command.
Please keep in mind that AD in 2008 has changed quite a bit relative to service principals.  There are now several additional options, and my guess is that the API has changed as well.
If you take a close look at the error messages from your code, you will see the following:
GetGC failed 0x1
DsMakeSpn(mpich2_smpd, central2.itlab.platform.com, 8676) failed: The parameter is incorrect.
So, we need to understand what GetGC is and why it failed, and then cascading to the DsMakeSpn.
Larry Adams
Senior Systems Engineer
Platform Computing
Tele: (586) 510-0007
Cell: (586) 899-1138
Skype: TheWitness
Message: 5
Date: Tue, 5 May 2009 16:23:11 -0500 (CDT)
To: "'Larry Adams'" <ladams at platform.com>
Message-ID: <02E9E54406CC4B4294228AF178AF7150 at mcs.anl.gov>
Content-Type: text/plain; charset="us-ascii"
 Can you run hostname without specifying "-hosts" (mpiexec -delegate -n
1
hostname) ? Also make sure that you are running mpiexec using delegation from a node with SMPD Service registered (Run "mpiexec -delegate -n 1 hostname" from a node where you executed "smpd -register_spn").
 Did you get any errors when registering SMPD Service Principal Name (smpd -register_spn)? Try removing the principal name and registering it again to verify (smpd -remove_spn ; smpd -register_spn).
Jayesh
  _____
Sent: Tuesday, May 05, 2009 2:18 PM
Subject: [mpich-discuss] MPICH2 Support On Windows HPC Server 2008
All,
I have attempted to get MPICH2 1.08 and 1.1 to work on Windows and receive the following error when performing the following command:
C:\Program Files\MPICH2\bin>mpiexec -delegate -hosts 1 central2.itlab.platform.com hostname
GetGC failed 0x1
unable to lookup the smpd Service Principal Name.
unable to initialize an sspi context command.
mpiexec aborting job...
I am absolutely certain that I installed smpd using the following command, and it was successful.
smpd -register_spn
Any help would be appreciated.
Larry Adams
Platform Computing
Skype: TheWitness
URL:
<http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090505/6
bd2fa67/attachment-0001.htm>
Message: 6
Date: Tue, 5 May 2009 18:09:37 -0400
To: <jayesh at mcs.anl.gov>
Message-ID:
<E2AC825D4FC7764DA86D9C8ECA27A2DE0238D3CC at catoexm05.noam.corp.platform.c
om>
Content-Type: text/plain; charset="utf-8"
I have tried all these.  It appears to be related to the win2008 domain controller.  Has it been tested in this config?
Larry
Sent using BlackBerry
To: Larry Adams
Sent: Tue May 05 17:23:11 2009
1 hostname) ? Also make sure that you are running mpiexec using delegation from a node with SMPD Service registered (Run "mpiexec -delegate -n 1 hostname" from a node where you executed "smpd -register_spn").
Jayesh
  _____
All,
GetGC failed 0x1
smpd ?register_spn
Larry Adams
Platform Computing
Skype: TheWitness
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090521/743a4155/attachment-0001.htm>
