[mpich-discuss] How to send SIGINT to each process
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed May 13 15:18:46 CDT 2009
 I am not sure if there is an easy way to do the cleanup. If there are
DLLs loaded by the MPI processes the entry point functions of the DLLs
should get called with "DLL_PROCESS_DETACH".
 You could change the design of your program by creating a thread to wait
for input from the user and terminate job accordingly (This would be
portable too).
Jayesh
  _____
From: abhishek pandey [mailto:hipandey at gmail.com]
Sent: Wednesday, May 13, 2009 2:32 PM
To: Jayesh Krishna
Subject: Re: [mpich-discuss] How to send SIGINT to each process
Hi Jayesh,
My program is designed to run continuously until it gets SIGINT. On
getting ctrl+C, it does some stuffs and then exits.
Now the onus is, mpiexec just kills the process and my program does not
end gracefully. So I need this signal to be passed to each process.
Abhishek
On Thu, May 14, 2009 at 12:48 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
 AFAIK, smpd does not provide a way to send signals like mpd.
 Why do you want to send signals to MPI processes ?
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of abhishek pandey
Sent: Wednesday, May 13, 2009 2:07 PM
Thanks for quick response.
Forgot to mention last time, I need to pass SIGINT to each process on
window/vista
 I am launching the job with
mpiexec.exe -configfile <configfile>.
and on each client, smpd.exe is installed.
Abhishek
On Thu, May 14, 2009 at 12:26 AM, Darius Buntinas <buntinas at mcs.anl.gov>
wrote:
If you're using mpd as the job launcher, you should be able to use
mpdsigjob.
-d
On 05/13/2009 01:54 PM, abhishek pandey wrote:
> Hi,
> Is there anyway to pass SIGINT signal to each process from mpiexe ?
> The problem is whenever I press ctrl+C, mpiexe kills all the processes
> and I am not able to customize the exit of my program.
> I tried to find out the answer on net but dint get anything.
> Thanks,
> Abhishek
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090513/d899393c/attachment-0001.htm>
